Getting a DAC to work with my Panasonic TC-P50UT50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-29-2012, 08:50 AM - Thread Starter
dallaslow's Avatar
Just got a Panasonic TC-P50UT50 and am loving it. However, the only audio out option is optical digital. I have a 2.1 speaker system that only accepts 3.5mm. I have purchased a Fii0 D3 DAC. Super cheap but I thought it would do the trick. Unfortunately, I have come to find out that it doesn't process Dolby Digital so all I get is noise. It doesn't look like the TC-P50UT50 has an option to turn off Dolby. Any suggestions?
dallaslow is offline
post #2 of 4 Old 08-07-2012, 03:53 PM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 31
SUBTITLE: TosLink OR Coaxial OR Analog - Too Many Options...
Originally Posted by dallaslow View Post
Just got a Panasonic TC-P50UT50 and am loving it. However, the only audio out option is optical digital. I have a 2.1 speaker system that only accepts 3.5mm. I have purchased a Fii0 D3 DAC. Super cheap but I thought it would do the trick. Unfortunately, I have come to find out that it doesn't process Dolby Digital so all I get is noise...
Any suggestions?
  1. Did you try the DAC with different inputs to be sure that it works?
  2. Did you remove both protective covers from the ends of the TosLink cable? redface.gif
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #3 of 4 Old 08-07-2012, 05:24 PM
Ratman's Avatar
Quoted: 1277 Post(s)
Liked: 1026
SUBTITLE: Food for thought.
If using the TV's internal tuner and there's no option in the TV's audio setup for PCM only, your options are very limited.
Ratman is online now
post #4 of 4 Old 08-07-2012, 08:31 PM
Quoted: 26 Post(s)
Liked: 31
SUBTITLE: Change, While Inevitable, is *STILL* a Royal PITA! tongue.gif
Everything was so much simpler, back in the 70s, when I was building my DynaKit Audio Equipment (Stereo-70, PAT-4, AF-6) and HeathKit 25" Color TV. Now I have some equipment with Digital TOSLink and some with Digital Coaxial, while my beautiful Onkyo TX-SV919THX (S-Video & Analog Audio) sits there like a dinosaur. mad.gif
I picked up a pair of *NICE* Altec Lansing ADA885 4.1 PC Speaker Systems several years ago (originally ~$400 a decade before eek.gif ; ~$40 a decade later cool.gif ) and the analog audio from my Panasonic 27" CRT would *BLAST* through the setup in the Living Room. Then, S-Video and Analog Audio disappeared. {tears} So, I eventually bought a pair of Panasonic LCDs, fed by HDMI switches and Component switches, but had to suffer with just the TV's speakers. So, I looked on Monoprice and looked on Amazon and tried an 'El-Cheapo' "TOSLink or Coaxial to Analog Converter" - NG! At full volume, I could hardly hear the ADA885. So, since the ADA885 also has a Digital Coaxial input, I fed it the output from my antique Pioneer DV-343 DVD Player. At full volume, with the A/C running, my wife couldn't hear her TMC movie from ~10 feet away. I had to turn the Surrounds into Stereo X 2 and place one next to her rocking chair for her to hear the show.
Maybe you could enlighten, or point me to a good site to read about the (as perceived by me!) deficiencies of TOSLink / Coaxial vs "Old School" Analog Audio.
Reply HDTV Technical
Panasonic Viera Tc P50ut50 50 Inch Plasma Tv
