Las Vegas: Help with adding OTA to my Home Theater system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-01-2012, 01:01 PM - Thread Starter
EpicVegas's Avatar
I wan't to cut the cord as many have, my question is what options is best for me?
I was looking at the Terk HDTVa antanna & will need some kind of tuner/receiver that will run into my HDMI matrix.
(matrix includes Epson 3010 projector.)
What receiver/tuner should I get?
It needs to have HDMI out with a built in tuner so I can have a channel guide option when surfing the channels. I do not need a DVR rec option.
EpicVegas is offline
post #2 of 8 Old 08-02-2012, 07:08 AM - Thread Starter
EpicVegas's Avatar
Bump
post #3 of 8 Old 08-02-2012, 08:33 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1030
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis
An antenna recommendation is difficult without knowing your location and possible restrictions.
Go to www.tvfool.com and post your info.
Ratman is online now
post #4 of 8 Old 08-02-2012, 09:32 AM - Thread Starter
EpicVegas's Avatar
post #5 of 8 Old 08-02-2012, 12:34 PM
Ratman's Avatar
Liked: 1030
At a quick glance, an HDTVi may work depending on the structure of your house/apt and relation to the x-mitters. You may not "need" an HDTVa.
post #6 of 8 Old 08-03-2012, 07:04 AM - Thread Starter
EpicVegas's Avatar
What receiver/tuner would you recommend? I was thinking about a Channel Master CM7001
post #7 of 8 Old 08-03-2012, 10:58 PM
Jedi Master's Avatar
Quoted: 12 Post(s)
Liked: 31
That one would work good also the Centronics ZAT502 HD will work fine. Those are the two I would choose from. Since you are 15 miles away from your stations the Terk antenna will work. I use the Terk TV 5 at my house and it works great.
Broadcast TV - a vital national public resource
Jedi Master is offline
post #8 of 8 Old 08-05-2012, 06:13 PM
Super Moderator
DrDon's Avatar
Quoted: 894 Post(s)
Liked: 1762
Thread title edited. ALWAYS include a location with antenna help threads. See the sticky.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Reply HDTV Technical
