Digital Cable Box conversion to HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-06-2012, 08:26 PM - Thread Starter
seiberr's Avatar
Hello all, I just recently bought a LED HDTV and I have a Dish Network digital cable box with no HDMI outputs. I'm wondering if there is a way I can convert the coax to an HDMI input to the television? Would love to hear responses and a quick fix I hope!
seiberr is offline
post #2 of 12 Old 08-06-2012, 11:17 PM
Otto Pylot's Avatar
Quoted: 1373 Post(s)
Liked: 858
Can you run coax out from the cable box to the ANT/CABLE input of your tv and then set your tv to cable and scan?
Otto Pylot is online now
post #3 of 12 Old 08-07-2012, 04:23 AM
ProjectSHO89's Avatar
Quoted: 215 Post(s)
Liked: 112
Upgrade the Dish Network service to HD if you want HD service.
With no HDM output, it's probably just a standard def receiver which will limit you to either the RF signal on channel 3/4 or the standard A/V connections (red/yellow/white).
ProjectSHO89 is online now
post #4 of 12 Old 08-07-2012, 04:42 AM - Thread Starter
seiberr's Avatar
Yes I can run a coax from my the box to my TV, however I only receive standard definition that way. I'm trying to find a way to getr HD out from the standard box. Could I use a digital to HDMI converter box? Run the coax from the Dish Digital standard definition box to the converter and then the HDMI from the converter to the television?
seiberr is offline
post #5 of 12 Old 08-07-2012, 05:13 AM
Ratman's Avatar
Quoted: 1290 Post(s)
Liked: 1030
You cannot magically convert a signal from an SD receiver to output HD. You have to buy or rent an HD capable receiver from Dish.
Ratman is offline
post #6 of 12 Old 08-07-2012, 06:40 AM
BCF68's Avatar
Because it's a standard definition box. You need to order HD service as others have said. Even if you had somehow obtained a HD box without HD service you're not going to get HD. I suspect you also have a dish that won't work with HD service either. Just call up Dish Network and order the service. You'll get the proper dish and box.
BCF68 is offline
post #7 of 12 Old 08-07-2012, 04:06 PM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 34
SUBTITLE: Are You Sure About That???
It sounds like you're asking to OP to scan for ClearQAM channels. But, isn't that a "Cable Only" option??? redface.gif
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #8 of 12 Old 08-07-2012, 04:10 PM
BCF68's Avatar
Yep satellite doesn't use QAM.
BCF68 is offline
post #9 of 12 Old 08-07-2012, 05:14 PM
Ratman's Avatar
Liked: 1030
Doesn't matter either way. Whether cable, FiOS, satellite or whatever. RF (coax) output from a provider's receiver will be a modulated NTSC (VSB) standard definition signal.
Ratman is offline
post #10 of 12 Old 08-07-2012, 07:30 PM
Quoted: 26 Post(s)
Liked: 34
SUBTITLE: Just Trying to Clarify Things for the OP...
A 'Channel Scan' on Cable or FiOS will detect SEVERAL ClearQAM channels while, AFAIK (never having used Satellite) a 'Channel Scan' on a Satellite STB will only detect the RF3/4 NTSC (and display whatever content the Satellite STB is currently tuned to). So why waste 15+ minutes scanning? Just manually tune to NTSC 3/4. cool.gif
I just wanted to point out to the OP that, IMHO, Otto Pylot's suggestion didn't seem very useful. If you have a SD STB (WAG since there's no HDMI output), whether Cable, FiOS or Satellite, you're going to get SD. If you want HD, you're (i.e. the OP) going to need a HD STB with HDMI and/or Component outputs. IIRC, S-Video and Composite will usually display a 'Postage Stamp' 16:9, requiring a ZOOM, instead of a Full Screen of data bits. frown.gif
I'm over 60 and just watching TV has become 'so interesting' since the introduction of ATSC to OTA *AND* the subsequent, NON- MANDATORY follow-up by Cable to dump NTSC, constantly shuffle the PSIP data for the ClearQAM channels, and thus, for 'Joe Public', require a STB / $$$ for *EACH* TV, DVR, VCR, yada, yada, yada... rolleyes.giftongue.gif
post #11 of 12 Old 08-08-2012, 05:16 AM
Ratman's Avatar
Liked: 1030
Sorry, but using the RF/coax output will be the same from any provider's STB. It will always be NTSC on the TV's channel 3 or 4.
Ratman is offline
post #12 of 12 Old 08-08-2012, 05:46 PM
ybsane's Avatar
Quoted: 95 Post(s)
Liked: 35
From Clearto land: Just manually tune to NTSC 3/4. OMG why not watch VHS with 3 movies on a 120 minute tape too...eek.gif I can't stand to watch SD on cable let alone modulated Ch.3/4 output.
All Comments made are my own and not of my employer.
ybsane is offline
Reply HDTV Technical
