Motorola RNG150N (Comcast) to Samsung S27A850D Monitor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-08-2012, 06:27 PM - Thread Starter
Montagar's Avatar
I have a Samsung S27A850D monitor that has a DVI-D (HDCP) input. The RNG150N cable box has an HDMI output. I have them connected together using an HDMI to DVI adapter. The setup menu in the cable box has a setting for HDMI/DVI that is to be used when using an HDMI to DVI adapter (stated in the manual). When I connect the monitor I get a picture very briefly and then just colored "snow". Has anyone experienced anything similar to this? Thanks.
"Sometimes, I guess, there just aren't enough rocks."
Montagar is offline
post #2 of 5 Old 08-11-2012, 02:57 PM
triple_vee's Avatar
If the cable box, using the HDCP protocol that is part of HDMI, cannot detect that the display is indeed a display, then the box can decide not to output over that HDMI port. I had this problem when running a comcast box into my AV receiver. I don't know if an HDMI to DVI adapter would prevent the HDCP handshaking between the cable box and your monitor. Try plugging into a monitor that has an HDMI input to test it out.
triple_vee is offline
post #3 of 5 Old 08-11-2012, 04:21 PM - Thread Starter
Montagar's Avatar
Thanks for the reply. I have tested the HDMI to DVI adapter with a different monitor that only has DVI and it worked, so I'm thinking it might be something specific to the Samsung monitor settings. I did a search and have found reviews and tests that suggest that it should work. It does the exact same thing when hooked up to a Blu-ray player.
Montagar is offline
post #4 of 5 Old 08-11-2012, 05:33 PM
triple_vee's Avatar
Ah, perhaps your Samsung doesn't respond properly to HDCP. Blu-ray players are notorious for insisting that they only be connected to a display device. They determine this via HDCP.
post #5 of 5 Old 09-07-2012, 10:14 AM - Thread Starter
Montagar's Avatar
Just to finish this off... finally was able to get a definitive answer from Samsung that this monitor will not work with HDMI->DVI
Montagar is offline
Reply HDTV Technical
Motorola , Samsung , Displays , Blu Ray Players
