Newbie with HDMI cable issues need advice plz! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-14-2012, 11:35 AM - Thread Starter
stringer99's Avatar
Hi I have put an older 50" 720p plasma above a fireplace at home. I ran two cheapie 50ft HDMI cables through back of fireplace to attic and back down through a wall in this TV room to hide cables. The cables have since stopped working, and the fireplace does not get used. I have used a shorter HDMI cable from tv to sattelite and blueray to confirm the cables are bad. Now i have to replace the cables. I have 11ft of cable slack from 50ft cables that come out of the wall, which is behind a couch.
Now what should i do, just buy two more 50ft cables? Or would a single cable work, and just get an HDMI splitter? I want to preserve the possibility of getting a 1080p set in the future and want whatever i decide on to work with that. Also should i bother to get an HDMI wall plate? Cables are just poked through wall at the moment. Any advice much appreciated. Thanks!
stringer99 is offline
post #2 of 10 Old 08-14-2012, 12:21 PM - Thread Starter
stringer99's Avatar
I was thinking, should i just get a single 40ft HDMI cable, an HDMI/Coax wall plate, and an HDMI switcher? I already have a smaller HDMI cord to run from wall to switcher. Thanks.
post #3 of 10 Old 08-14-2012, 06:42 PM - Thread Starter
stringer99's Avatar
post #4 of 10 Old 08-15-2012, 06:15 AM - Thread Starter
stringer99's Avatar
help please
post #5 of 10 Old 08-15-2012, 07:37 AM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1180
I'll offer a suggestion and an opinion.
1) figure out how or why two HDMI cables "went bad". (critters chewing cables? Construction work that damaged cables?)
2) if this configuration worked before, I'd not choose to add a HDMI splitter. A wall plate is your choice for cosmetic purposes only and is your option.
You may have a problem finding a 50' High Speed HDMI cable for 1080p (at an affordable/practical price from a "reputable" manufacturer)..
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #6 of 10 Old 08-15-2012, 07:42 AM - Thread Starter
stringer99's Avatar
the 50ft HDMI cables i used cost around 13 bucks. i assume cables that cheap are hit and miss. so i guess ill just go ahead and get two better quality cables then? they are undamaged. thanks.
post #7 of 10 Old 08-15-2012, 08:25 AM
Ratman's Avatar
Liked: 1180
I'll aska again.... did the configuration (cables) ever work? I'd guess that 50' for $13, it's more "miss" than bargain. wink.gif
For 50', you should not get anything other than 22AWG cables. Getting a "standard speed" HDMI to work with 1080p @ 50' is hit or miss.
Just as an anecdote:
My neighbor had an HDMI cable "go bad". After careful inspection (by yours truly), I found that the outer jacket had been chewed by his cat. Only found it by "feel". The damage was not easily visible.
post #8 of 10 Old 08-15-2012, 10:56 AM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1020
You need Certified High Speed HDMI cables. Most cables, from reputable mfrs as mentioned above, are certified to about 25' but you want to make sure that the cable you buy is certified for the length you buy. Monoprice, MediaBridge (that's what I use), BlueJeans all make good, certified cables at very reasonable prices. Stay away from the other "M" brand because their costs are unreasonably high and you don't really get a better cable than from the others. You can get certified cables at longer than 25' but you really have to shop carefully and know what you are buying. For the definitive answers to your HDMI cable questions, I would go to the HDMI thread and post your questions there.
Otto Pylot is offline
post #9 of 10 Old 08-17-2012, 08:24 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
Did both cables go bad at the same time? That seems too much of a coincidence.
HDMI Guy is offline
post #10 of 10 Old 08-17-2012, 08:39 PM
Otto Pylot's Avatar
Liked: 1020
Maybe. But if he's got 50' cables for $13..... quality built?........
Reply HDTV Technical
Plasma Hdtv
