Need help connecting component cables to HDTV and region free DVD player. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-14-2012, 10:19 PM - Thread Starter
Dan55's Avatar
I see the cables I need are red and white for audio and I don't see a yellow for video I only see two blue cables, one of them is a tealish blue the other one is a dark blue. Since there is no yellow for video which do I plug in then? Also which ones do I hook into the DVD player in the back of it?
Dan55 is offline
post #2 of 3 Old 08-14-2012, 11:08 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Component video cables are typically Red, Green, and Blue for video, and the usual red/white pair for audio. Five wires. They connect to the appropriately colored/labeled jacks on the back of the DVD player. This is all explained in the DVD player's manual and the TV's manual.
domino92024 is offline
post #3 of 3 Old 08-15-2012, 03:44 PM
holl_ands's Avatar
Quoted: 440 Post(s)
Liked: 182
Alternatively, if they both have HDMI ports, you can connect with a SINGLE HDMI cable...no other cables required.
HDMI interface carries BOTH digital video and digital audio, so separate Red/White audio cables are NOT required.
BTW: The YELLOW composite video interface is LOW-REZ. Only HDMI and Component Video (RGB) are Hi-Rez.
holl_ands is offline
Reply HDTV Technical
