Quad RG-6 Recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 08-18-2012, 04:37 PM - Thread Starter
Scooby06's Avatar
Looking for some Quad Shield RG-6 cable for a new satellite install.I only need around 125-150 ft,but all I seem to see is 500ft+.Most of them are copper-clad and not copper.Any particular brands I should check? Places that may have the amount I need?
Scooby06 is offline
post #2 of 24 Old 08-18-2012, 05:03 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
I use Belden 7916a, but I normally buy it in the 500ft box from broadbandutopia.com. Currently the 500ft box is around $84. They also have a 150ft pre-made cable for $40.. I guess you could cut it up to suit your needs . . .
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&sqi=2&ved=0CGMQFjAA&url=http%3A%2F%2Fwww.belden.com%2Ftechdatas%2Fmetric%2F7916A.pdf&ei=Jx4wULPKOILk9ASKkIGIAg&usg=AFQjCNGwnoAvELfhN_Q-rQevHOzQtU6Iow
http://www.broadbandutopia.com/belcoax7916a1.html
http://www.broadbandutopia.com/150febequshr.html
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 24 Old 08-18-2012, 05:14 PM - Thread Starter
Scooby06's Avatar
Just wish I had a need for 500ft.Seems like a good deal. As for the 150 ft,I could cut it up and make the lengths I need since I have all the tools and connectors to terminate them. The solid copper core is a plus also.
Scooby06 is offline
post #4 of 24 Old 08-18-2012, 07:11 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Ebay is your friend. Just take the remaining footage and offer custom cuts. You may not get your entire purchase back but it may be something.
Otto Pylot is online now
post #5 of 24 Old 08-18-2012, 07:55 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
What's your application that solid copper would make a difference? Are you expecting it to carry a high current?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 24 Old 08-18-2012, 08:52 PM - Thread Starter
Scooby06's Avatar
I have one run that will be around 75ft and a co-worker said since the two were kind of in the same price range to go ahead and go with the solid core copper instead of the clad-steel.Was I told wrong?
Scooby06 is offline
post #7 of 24 Old 08-18-2012, 10:16 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
If it's for RF then because of the skin effect either is fine. The copper clad steel is a bit more robust mechanically and a bit cheaper. That's why 99.9% of Cable TV installations use it.
olyteddy is offline
post #8 of 24 Old 08-19-2012, 04:58 AM
ProjectSHO89's Avatar
Quoted: 206 Post(s)
Liked: 109
Solid core copper will have an advantage only if you're running DC power through the coax and then, usually only on longer runs as it has a lower DC resistance per unit length. At RF frequencies, either type is equivalent.
Similarly, there's no need for quad-shield in most antenna installations, but since you're doing a satellite install, you should stick with the QS variety.
Unless your application demands otherwise, let price and quality be your determining factors.
ProjectSHO89 is online now
post #9 of 24 Old 08-19-2012, 09:08 AM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
I prefer the solid copper because I find it easier to work with.. softer and more flexible.
Blu-rays & DVD's
WS65711 is offline
post #10 of 24 Old 08-19-2012, 07:03 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
That is also its downfall. The center terminal of an 'F' connector is the center conductor and copper clad steel is stiffer, ensuring good penetration of the female connector.
olyteddy is offline
post #11 of 24 Old 08-19-2012, 07:33 PM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
Last time I checked, there were several eBay sellers who sold pre-cut, pre-connectorized cables, and if you wanted an exact " 'tweener" length, you can usually get those sellers to make one up and list it as a Buy-it-now.
AntAltMike is offline
post #12 of 24 Old 08-20-2012, 06:08 AM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Blu-rays & DVD's
WS65711 is offline
post #13 of 24 Old 08-20-2012, 12:55 PM
kenglish's Avatar
Liked: 39
Just don't let the steel scratch the copper (or other metal) of the connector and damage it.
Cable TV guys found out, long ago, that a burr on the edge of dissimilar metals will cause a diode-effect, and increase inter-modulation distortions.
They even use a special tool to smooth the edges of the center conductor in the big semi-flex cables.
For RG-6/U and similar, just use a very good "flush-cutter". I also run my finger over the end, or wipe it across my jeans or shirtsleeve, to see if there's a jagged edge.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #14 of 24 Old 08-20-2012, 08:41 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I'm interested in that. I spliced for about 20 years and never used anything fancier than a pair of Klein 'Nines' (standard electrician pliers). I do however have fancy plastic scraper to remove the residual foam from the center conductor after coring the cable.
PS: FWIW, most trunk and feeder cable center is copper clad aluminum, with an aluminum tube for the sheath.
olyteddy is offline
post #15 of 24 Old 08-21-2012, 08:25 AM
kenglish's Avatar
Liked: 39
The tool I have is called a "Cable Gator", and it has the usual fiber scraper blades on the end (for removing the foam), and a thing like a pencil sharpener on the side of it, for taking off the burr.
kenglish is offline
post #16 of 24 Old 08-21-2012, 08:42 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
You can find some of those tools at http://www.techtoolsupply.com/SearchResults.asp?Cat=46
CIAO!
Ed N.
egnlsn is offline
post #17 of 24 Old 08-21-2012, 09:01 AM
Beerstalker's Avatar
Liked: 24
You said this was for a satellite install. What satellite? If it's DirecTV their standards do call for solid copper core instead of copper clad steel last I knew.
Beerstalker is offline
post #18 of 24 Old 08-21-2012, 10:29 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Yeah, they do call for solid copper core. I wasn't going to replace all of my CCS cable just to make them happy, though. If you're under ~140', you'll be fine.
CIAO!
Ed N.
egnlsn is offline
post #19 of 24 Old 08-21-2012, 11:47 AM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
Well golly....
If it's a new install, get solid core copper and you're done. If it's a retrofit, take your chances.
Ratman is offline
post #20 of 24 Old 08-21-2012, 07:26 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I'll be go-to-heck. I've spliced hundreds of miles of trunk and feeder and never seen anything like that! Never had a problem on new build but on some retro jobs I've had to cut the stinger twice at right angles making a pyramid. Nice find.
olyteddy is offline
post #21 of 24 Old 08-22-2012, 08:24 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
We didn't use those until we upgraded from 330 to 550MHz. Prior to that, our knives sufficed. But the higher frequency system needed a little more TLC. A blade can scrape off too much copper. Not near as much of an issue with 330 as it is at 550. Let alone 750 nowadays.
CIAO!
Ed N.
egnlsn is offline
post #22 of 24 Old 08-22-2012, 10:34 AM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
750 nowadays? I think of 750 MHz as the "skipped threshold". Every system I have ever been involved with went right from 550 to 860. In fact, we broadcast MATV people make out like bandits buying 750 MHz amplifiers on eBay dirt cheap because there is a gigantic surplus of them.
post #23 of 24 Old 08-22-2012, 01:11 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Around here, there are a few spots that are 860, but most of the plant is 750. Why Comcast did that, I have no idea.
CIAO!
Ed N.
egnlsn is offline
post #24 of 24 Old 08-22-2012, 09:44 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I'm in 750 country here too. The last cable placement in my town was QR cable (.540 feeder, .860 trunk) at 750MHz spacing and Antec 550MHz gear. The systems around us used the Antec 550 amps at 860MHz spacing. We got 'upgraded' to Antec 750MHz amps and the rest got 870MHz Motorola. We also built everything out to the ocean at 870MHz spacing. I also built Click! in Tacoma (all .715 QR cable, 870MHz Motorola).
olyteddy is offline
Reply HDTV Technical
