Is this a true stripline combiner ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-20-2012, 06:56 AM - Thread Starter
JAVSF's Avatar
Found this while searching with Google (something that appears to have less and less results nowdays...).
http://www.serigo.ee/product_info.php?products_id=78881&language=en&osCsid=8a380b415684a72e5f840c9937cded2f
Looking at the PCB it doesn't seem to have the topology I've seen on other stripline combiners, yet it mentions .2db loss in the specs.
Anyone had any experience with these ?
Regars
José
JAVSF is offline
post #2 of 4 Old 08-20-2012, 06:59 AM - Thread Starter
JAVSF's Avatar
By the way, you can view much bigger pic of it if you click on the image...
JAVSF is offline
post #3 of 4 Old 08-20-2012, 02:07 PM
holl_ands's Avatar
Quoted: 434 Post(s)
Liked: 179
It looks more like a simple two step Wilkinson impedance transformer, using quarter-wavelength "stubs":
http://www.microwaves101.com/encyclopedia/Wilkinson_splitters.cfm
http://whites.sdsmt.edu/classes/ee481/notes/481Lecture9.pdf
As additional stages are added, the bandwidth can be extended (as we need for TV Bands):
http://www.ijser.org/researchpaper%5CEffect-of-Adding-Input-and-Output-Impedance-Transformer-on-Wilkinson-Power-Dividers-Performance.pdf
Call Triax and ask them to provide an insertion loss vs frequency plot when used as a combiner.
BTW: That brochure is from 2006 and the p/n is not found in 2008 and later catalogs,
so don't be surprised if they no longer make that part.
holl_ands is offline
post #4 of 4 Old 08-21-2012, 05:14 PM
fastl's Avatar
Quoted: 22 Post(s)
That is not stripline, it's microstrip. The transmission line is buried between ground planes in stripline.
fastl is offline
Reply HDTV Technical
