El Dorado Hills, CA OTA PBS and ABC Channel missing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-20-2012, 11:50 AM - Thread Starter
rsah12's Avatar
I can't get ABC and PBS via over the air antenna from El Dorado Hills, CA. I am using Clear Stream 4 antenna from Antenna Direct, I get most other channels just fine. What can I do?
rsah12 is offline
post #2 of 6 Old 08-20-2012, 12:10 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Do you need to add a VHF antenna? Is ABC on RF7?
tylerSC is offline
post #3 of 6 Old 08-20-2012, 12:49 PM - Thread Starter
rsah12's Avatar
I think I do need to add something to get these two VHF signals, do you think rabbit ears would help?
rsah12 is offline
post #4 of 6 Old 08-20-2012, 10:02 PM
deltaguy's Avatar
Quoted: 17 Post(s)
First, where is your antenna located?
deltaguy is offline
post #5 of 6 Old 08-21-2012, 05:26 AM
ProjectSHO89's Avatar
Quoted: 210 Post(s)
Liked: 110
ABC and PBS in the Sacramento area require a high-VHF antenna. The C4 is a medium-to-long range UHF antenna but is fairly blind on high_VHF.
Antennas Direct makes a simple VHF add-on for their C2 antenna that can easily be installed on a C4. Just swap out one of the stock reflectors and rewire it. While not optimally located, it does well enough for most folks for up to medium range high-VHF antenna and avoids either the expense or the physical size of a second or larger combo antenna. Look for it under Accessories > Reflectors on their website.
ProjectSHO89 is offline
post #6 of 6 Old 08-21-2012, 12:35 PM
mikepier's Avatar
Quoted: 16 Post(s)
Post your tvfool results so we can get an idea of reception in your area.
mikepier is offline
Reply HDTV Technical
