Crazy accident and my LCD was struck, is it terminal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-25-2012, 11:44 PM - Thread Starter
vettejock99's Avatar
So last night I put a book on the top shelf of my built in and the shelf slides off its brackets. Book comes down, as does a speaker. Speaker, attached to wire, becomes a pendulum and swings down into my 55 inch tv. It looked fine, with no crack or search to the case, but now when I turn it on there are lines across the side and bottom as shown in the attached pics. I guess the inner screen cracked. Any idea of this can be fixed for a reasonable amount or if I have to replace it?
Sent from my Transformer TF101 using Tapatalk 2
vettejock99 is offline
post #2 of 4 Old 08-26-2012, 12:54 AM
BCF68's Avatar
I would say you're going to have to pay to get it fixed if it can be fixed. May be cheaper to buy a new TV. Use this as a learning moment. Never put anything over the top of your TV.
BCF68 is offline
post #3 of 4 Old 08-26-2012, 06:28 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
You're hosed..a new panel with installation will cost more than a new tv..
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #4 of 4 Old 08-30-2012, 05:12 AM
videobruce's Avatar
Quoted: 597 Post(s)
Liked: 246
+1 Toss it. (Though, you could remove the back cover and re-seat all the connectors and try that on the chance one became dislodged.)
Lesson; don't place anything above a TV. Almost as bad as mounting a TV above a fireplace. rolleyes.gif
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Reply HDTV Technical
