Comcast HD image “too big” - not an aspect setting issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-03-2012, 09:36 AM - Thread Starter
HNick's Avatar
Last week everything on Comcast HD was fine.
Over the weekend, I noticed the problem - during a baseball game in HD, the score display in the upper left only showed the visitors half of the display. The same problem was visible on the Weather Channel - graphics along the edge were only partly visible.
I tried all the aspect settings - they made the problem worse (including 4:3), as none of them make the source image smaller.
My first thought was that Comcast made some change, but I reviewed my settings in case I accidentally changed something. So, I rebooted the DVR - same problem after.
Current display related settings are:
DVR: Cisco RNG200
Menu>Setup>Screen Position Setup: the arrows are centered on the screen
BTW, the HD Zoom button on the remote has no effect
A/V Receiver:
Menu>Input/Output Assign>Monitor Out>Resolution: Auto
Menu>Source Setup>Picture Adjust>Wide Mode: Auto
Menu>Source Setup>Picture Adjust>Picture Mode: Direct
TV:
Menu>Picture>Picture Mode: THX
Menu>Picture>Aspect adjustments>Screen format: Full
Menu>Picture>Aspect adjustments>HD Size: 2
The “FULL” and “2” settings displayed the most picture area
Again, the various aspect settings neither fixed nor improved the problem.
Before I call Comcast (sigh), does anyone have any ideas to try?
HNick is offline
post #2 of 3 Old 09-03-2012, 01:00 PM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
By "reboot" do you mean power off then on, or remove power, wait several minutes, reconnect power and turn it back on? I have a media player that glitches the picture size every now and then when an mpeg video has a glitch. It requires a power cycle to correct itself.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
post #3 of 3 Old 09-03-2012, 01:34 PM - Thread Starter
HNick's Avatar
Fixed!!
Called Comcast and the nice lady told me what to do.
Turn DVR on. Then turn it off and quickly press and hold the "menu" and "info" buttons.
An HD setup screen appears. Follow the directions.
HD is now correct again.
HNick is offline
Reply HDTV Technical
