Run standard definition channels on LED TVs? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 09-16-2012, 08:58 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Originally Posted by videobruce View Post
What's a "LED TV"?
Originally Posted by lovinthehd View Post
...it, but the LCD (LEDs are just a way of lighting an LCD set) .
Ratman is offline
post #32 of 35 Old 01-24-2013, 02:03 AM
FiveOhFour's Avatar
Originally Posted by yorkmapper View Post
Can I run channels in standard definition on an LED TV? I have a Samsung 6100 Smart TV but do not have HD. I do have basic cable. The non-HD channels display poorly. Thanks.
I think the easiest and most direct answer to your question may be as follows, and that you simply gave up with all the back and forth discussing things far past what you were asking. From what you say it sounds like you have basic cable, so all channels are SD whether digital or analog signal. This will give you terrible SD picture, for cable channels there is little you can do however for anything you are capable of getting over the air from a standard antenna, you can get varying degrees of HD quality programming depending on where you live and it often surpasses the HD version of your local channels delivered through the cable co., I think someone was heading down this road but brought up converter boxes and such which is but I think IMO at least the simplest way for you to get much better picture is to go to radio shack and buy a coax splitter, engage the salesman and let him know what your doing and he'll help you get the proper splitter and an antenna, although I would suggest getting a cheaper but highly rated antenna online, unless you are far from the city and the channels source and you need a full fledged roof mounted antenna, which are still cheap at RadioShack, and you'll be pulling in 20'ish HD channels and even more SD that look much better. Your tv definately has a built in ATSC tuner so pulling HD channels in OTA is no issue.
FiveOhFour is offline
post #33 of 35 Old 01-24-2013, 01:29 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
I think the easiest and most direct answer to your question...
Enjoy reviving threads that died 4 months ago?
domino92024 is offline
post #34 of 35 Old 01-24-2013, 02:41 PM
Ratman's Avatar
Liked: 1028
Ratman is offline
post #35 of 35 Old 01-24-2013, 04:14 PM
Super Moderator
DrDon's Avatar
Quoted: 877 Post(s)
Liked: 1734
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Reply HDTV Technical
Led Hdtv , Displays , Lcd Hdtv , Samsung Un46es6100 46 Inch 1080p 120 Hz Slim Led Hdtv Black
