Does Comcast hook up 2 separate cable connections to the house (internet vs tv)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-05-2012, 10:33 AM - Thread Starter
drocpsu's Avatar
So i was just on the phone with Comcast canceling my TV and phone service (but keeping internet) and the customer service rep I was talking to said they'd have to schedule an appointment for Comcast to come out and disconnect my cable tv service. She said they connect 2 lines to the house; one for tv and one internet.
Is this accurate?? I consider myself to be technically savvy, but that doesnt make any sense to me. Why would Comcast run separate lines for services that are distributed through the house over a single line? It seems like that would make for additional, unnecessary distribution costs. Does anyone know anything about this? I'm curious.
drocpsu is offline
post #2 of 6 Old 09-05-2012, 12:56 PM
rdoac's Avatar
In my area (Rockford, IL) they run one line to a little grey box on the outside of the house, it goes through a grounding block and then to a two way splitter, one cable is labelled (phone - which is a lie) and goes to the cable modem, the other goes to a 3 way splitter to the TV lines. If they come, they may disconnect the three way splitter (or equivalent) and put a lock on the two way splitter, which is easily removed (they did this to my Mother in laws even though she has Basic cable??).
As an aside, it is cheaper here to get internet + basic tv ($9 local qam channels only) that just internet as they then charge you for a one service only fee of $15. We get our landline through Nettalk which is about $30 per year for unlimited calling over VOIP.
rdoac is offline
post #3 of 6 Old 09-05-2012, 01:02 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
One line/coax for everthing. Although, they may do a truck roll to install a trap/filter to block TV.
But.... it really doesn't matter either way or what they do, you're cancelling the subscription. wink.gif
Ratman is online now
post #4 of 6 Old 09-06-2012, 09:00 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
It's going to vary from area to area and from installer to installer.  In my case a single cable comes from the pole but there's a splitter on our house wall to divide the downstream connection that we use for Internet and phone from the two that go to other parts of the house for television.
dattier is offline
post #5 of 6 Old 09-07-2012, 10:58 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
There's a splitter alright, but it doesn't separate downstream from upstream. Almost every part of a coax cable system is two way.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 6 Old 09-08-2012, 09:06 AM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
I wasn't implying that it did.  My use of the word "downstream" was only to indicate in which direction the device called a "splitter" was doing a job of splitting.  With a perspective of looking upstream I'd have had to call it a combiner.
Yes, of course.
dattier is offline
Reply HDTV Technical
Displays , Cables Interconnects
