Why is my picture better with component than with HDMI cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-08-2012, 04:39 AM - Thread Starter
basil lambri's Avatar
I have a question, why it seems that my TV picture is better with component cables than with HDMI, and I was wondering if you guys can help me with that. I think that the picture on my Samsung HDTV looks much better with component than with HDMI cables. I have Time Warner Cable.
I had read somewhere that there is a technical reason why that might be happening but I forgot what I read. It was saying that it had to do with more color information from component or something like that.
I think the picture is better like that with both HD and standard definition programs.
Maybe that is not happening with newer TVs-my Sammy is a 2010 model. Also, HDMI technology will improve in the future. But for now I am happy with the component connection.
basil lambri is offline
post #2 of 12 Old 09-08-2012, 06:54 AM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
Each input of the TV has it's own individual adjustments. Have you tried tweaking them? If adjusted properly, you should see the exact same picture quality with a cable TV source.
Digital Rules is offline
post #3 of 12 Old 09-08-2012, 07:43 AM - Thread Starter
Yes, I have tweaked the picture controls. Actually, I have used the Digital Video Essentials BD calibration disc to calibrate the picture. But I think the same thing is still happening.
post #4 of 12 Old 09-08-2012, 07:56 AM
walford's Avatar
Are you using the TW cable STB to convert the incoming program to the same resoluition when sending to both HDMI and Component? Do you see any difference between program sources, 720p, 1080i, or 480i?
walford is offline
post #5 of 12 Old 09-08-2012, 08:31 AM - Thread Starter
My Time Warner Cable set-top box changes the resolution automatically according to the channel source, 1080i, 720p, etc., in both the component and the HDMI inputs. I notice that the programs in 720p (my TV's native resolution) and 1080i look sharper than 480i. They also look more exciting.
post #6 of 12 Old 09-08-2012, 11:19 AM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
It's always possible the component signal is a bit softer, thus hiding some of the flaws in the signal due to excess compression.
phildaant and Cabal0 like this.
NetworkTV is offline
post #7 of 12 Old 09-09-2012, 06:13 PM
walford's Avatar
SD 480i video content will always look softer when it uipscaled to 720p or 1080p since the TV has to invent the content of the additional pixels to be displayed. Top of the line and newer TVs have better upscaling video chips the other models.
walford is offline
post #8 of 12 Old 09-10-2012, 02:11 AM
techfreak191's Avatar
I don't know how Component vs HDMI effects digital TV, but here's what it does when we talk console games (running at 720p or upscaled 1080p):
Component cables transfer an analog signal, meaning there is a little bit of distortion, making the image appear smooth and soft, thus hiding image flaws, like one member pointed out.
HDMI is 100% digital, the cleanest signal you could possible expect from an HDTV. This means that whatever imperfections, flaws or anomalies the source may have, will be clearly visible. However, HDMI does offer more crispiness, sharpness and clarity. In some cases, even better colors. You may need to buy a good-quality HDMI cable (Monster comes highly recommended, but pricey), and tweak your TV for HDMI. You will definitely experience better sound with HDMI cables too.
In addition, HDMI may also offer slightly better motion clarity and screen refresh. Hope this helps.
techfreak191 is offline
post #9 of 12 Old 09-10-2012, 06:01 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Just say no to Monster cables! Monoprice or Blue Jeans or even Amazon will get you just as good a cable at a fraction of the cost.
joed32 is offline
post #10 of 12 Old 09-10-2012, 12:29 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
He drank the kool-aid!!
domino92024 is offline
post #11 of 12 Old 09-10-2012, 12:51 PM
SAM64's Avatar
Liked: 78
..and popped a handfull of pills too.
SAM64 is offline
post #12 of 12 Old 11-16-2012, 10:35 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
I also use component for my Cox box. It has a better picture and Cox fully admits it. Their hi-def box only supports up to 1080i and I just think it's their weak hardware that makes the hdmi connection look a bit less crisp. I tried three different box's and then just gave up and stayed with using component. You just might have the same issue.
mgh26 is offline
Reply HDTV Technical
Displays , Samsung , Cables Interconnects
