Is there a way to add more usb ports to an HDTV? Samsung? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-09-2012, 09:04 AM - Thread Starter
pcumming's Avatar
I have one USB port and I realize there are HDMI switchers. Can you add a port multiplier (like on a PC) on an HDTV? Does it need to be a powered one (ac adapter)?
Just wondering even though I do not know of a use for it yet..
Peter
pcumming is offline
post #2 of 6 Old 09-09-2012, 10:06 AM
swampystorm's Avatar
Yes, you need an HDMI switch.
Are you in the UK?
swampystorm is offline
post #3 of 6 Old 09-09-2012, 10:07 AM
Are you in the UK?
Sorry I thought you said HDMI!
Im not sure if a USB hub would work?
post #4 of 6 Old 09-09-2012, 10:17 AM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
Peter
Well, it really depends on what the USB port does on the TV.
In my case, the USB port is just for diagnostics. It doesn't let you connect anything.
Even if you can connect things like a thumb drive to watch content, the TV may not have the necessary drivers to sort out a hub. Further, it may only have provisions to control one device at a time. For example, my Roku has one designation for "USB Drive". It's one channel only.
It would be like trying to run two devices into one input on your stereo. The stereo only is meant to see one device per input at a time.
The reason an HDMI splitter works is that it's toggling between devices and sending only one at a time to the input. USB hubs send everything to a single port all at once. A computer can sort it out because it can assign ID's to each one individually (known as IRQs). Most multimedia devices don't have that capacity. They control one device at a time on one port.
NetworkTV is offline
post #5 of 6 Old 09-09-2012, 09:24 PM
Brucew0617's Avatar
As I known, there are some gadgets can switch your USB port to HDMI port so that you can use a USB Hub to hold HDMI and USB both. And you can just get a USB Hub with ac adapter.
Brucew0617 is offline
post #6 of 6 Old 09-10-2012, 08:50 AM
SAM64's Avatar
Liked: 78
this is done often, with no damage. In fact, audio mixers are designed to do just this.
No, splitters don't switch anything. They send the same thing to both outputs.
No, this is not possible on an arbitrated bus.
No, device ID's are not IRQ's
SAM64 is offline
Reply HDTV Technical
Roku , Cables Interconnects
