HDMI Handshake issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-20-2012, 06:48 PM - Thread Starter
Biggus Doggus's Avatar
Having a handshake issue with an older Vizio 46" LCD GV46L. I have troubleshot the problem by powering on/off devices/TV with and without the HDMI plugged in, getting video with no audio. Using the same set up, I swapped the 46" Vizio with a newer 22" Vizio, no issue, audio and video no problem. Other devices have no issue on the 46" HDMI ports, so not a port issue. Not a cable issue either, because if used with 22" TV, all works fine. Is it possible that this 2006 model Vizio has an old version of HDMI that this cable doesn't like?? The cable is probably from 2007 maybe even 2006. Any advice? Suggestions for forcing a good handshake.
Biggus Doggus is offline
post #2 of 6 Old 09-28-2012, 10:07 AM
cavt3604's Avatar
I'm having a similar issue with my TV. Same model, using DirecTV HD25-500. Did you ever fix your issue?
cavt3604 is offline
post #3 of 6 Old 09-28-2012, 10:53 AM
Colm's Avatar
Liked: 94
No, the cable is just a conduit for the signals. The pinout hasn't changed since day one, except for the changes made to support ethernet.
Colm is offline
post #4 of 6 Old 09-28-2012, 11:16 AM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
There is a range of acceptable HDMI levels for inputs and outputs. Chances are your older Vizio wants a higher level than does your newer Vizio. If so, a simple HDMI amplifier might solve this.
http://www.amazon.com/Bytecc-Repeater-Extender-version-1m-35m/dp/B0030HQ39M/ref=sr_1_2?ie=UTF8&qid=1348855925&sr=8-2&keywords=hdmi+amplifier
domino92024 is offline
post #5 of 6 Old 09-28-2012, 01:04 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
The repeater may be an option/solution, but I would first ask... how long is the HDMI cable(s). If under 20' and using a decent cable, perhaps "levels" aren't the issue. wink.gif
Taking length and/or quality issues into consideration, I'd first look into a better (guage) HDMI cable.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #6 of 6 Old 10-01-2012, 05:30 AM
cavt3604's Avatar
You might try this.
http://www.amazon.com/gp/product/B0015YWKYY/ref=oh_details_o04_s00_i00
I was having a similar issue, and once I hooked my switcher up, I was able so see HD via the HDMI cable
cavt3604 is offline
Reply HDTV Technical
