CEC STB question (Samsung SMT-H3362) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-21-2012, 08:22 PM - Thread Starter
OniFactor's Avatar
Okay, i'm trying to get it so that i can control my TWC-issued STB with the remote that came with my AVR. the AVR is a Sony STR-DN1010, and i know it supports HDMI-CEC. the problem comes in that i can NOT find ANY documentation on the Samsung cable box. NONE. Time Warner support has been less than helpful, as usual (chat agent gave me a hookup diagram for BASIC cable. no STB at all. uhhh?)
So, i guess it boils down to this. I'm begging you AVS gurus, do any of you know if the Samsung SMT-H3362 cable box is HDMI-CEC compliant? if so, how do i enable it? if it's not, should i just program the generic TWC remote that came with the STB to control the AVR? i can't stand having two huge remotes like this kicking around... Thank you!
OniFactor is offline
Reply HDTV Technical
