Component Video Splitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-26-2012, 05:17 AM - Thread Starter
hardcorecamraman's Avatar
Looking for people's thoughts on this:
http://www.bestbuy.com/site/eForCity+-+3+x+Ultra+Series+RGB+Component+Video+Splitter+-+8+-+Black/4575469.p?id=1218492328528&skuId=4575469&st=component%20video%20splitter&cp=1&lp=1
I am connecting a second tv to me home theater(kitchen/bar area) and I was told I could connect it to the cable running to the projector. This way, I would only have about 10ft of cable needed to run to the second tv and they both would be connected to the receiver. Pros? Cons?
Thanks everyone!
hardcorecamraman is offline
post #2 of 14 Old 09-26-2012, 05:32 AM
Xylon's Avatar
That works.
Xylon is offline
post #3 of 14 Old 09-26-2012, 07:16 AM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
From the picture, it appears that the cables are very thin (cheap/flimsy). You may be better off with one of these:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10422&cs_id=1042205&p_id=2848&seq=1&format=1#largeimage
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10422&cs_id=1042205&p_id=2899&seq=1&format=1#largeimage
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4 of 14 Old 09-30-2012, 06:10 AM - Thread Starter
What about a distribution amp? I was originally going to run everything out of my receiver but then I would need to have my receiver on. What if I ran each component to the distribution amp and then out to the receiver and out to the second tv? Then again this is probably a pricey setup. Any thoughts?
post #5 of 14 Old 10-13-2012, 11:40 PM
sawyerthecat's Avatar
I ordered the component cables and non powered splitter from monoprice though anticipating I will need to get from amazon the cable electronics labs composit dist amplifier to maintain brightness.
I have SD(480i), 720i, and 1080i and one comcast digital cable box. so hdmi splitting didn't seem to make sense for me due to lowest common denomenator.
I am running 35' to component video two the two lower resolution tvs.
sawyerthecat is offline
post #6 of 14 Old 10-14-2012, 06:10 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
I used one with a 25' run and had no problems.
joed32 is offline
post #7 of 14 Old 12-16-2012, 10:04 PM
bunalz's Avatar
bunalz is offline
post #8 of 14 Old 12-17-2012, 03:58 AM
Ratman's Avatar
Liked: 1158
Originally Posted by bunalz View Post
Sorry for the intrusion, but is it possible if I use those splitters with a YPrPb cable instead? I couldn't find anything except this one: http://www.cables.com/Products/SB-3776BNC.aspx
The device you linked to has BNC connectors. You would need to purchase BNC to RCA adapters.
post #9 of 14 Old 12-17-2012, 05:14 AM
bunalz's Avatar
Yep. Better than nothing I guess.
Thanks for the reply!
Something interesting. A video showing how he used the RGB splitter CONNECTED to another standard Y-splitter, then connects with a standard cable to record PS3 footage.
Your opinions on this?
bunalz is offline
post #10 of 14 Old 12-17-2012, 06:36 PM
Rory Boyce's Avatar
You can not properly split analog video using a Y adapter. These things may make a picture but they are junk if they do not contain an active video amplifier capable of driving two or more loads.
Video is usually sent using a sending end source impedance of 75 ohms over 75 ohm cables to a receiving device that terminates the signal in 75 ohms. If this is done all of the signal energy transmitted is absorbed by the receiving 75 ohm load. If the receiving impedance is not 75 ohms some of the signal energy is not absorbed but is instead reflected as a wave traveling back toward the sending end. If the sending end impedance is 75 ohms the reflected energy is absorbed at the sending end and all is OK. If the sending end impedance is also not 75 ohms some of the energy traveling back to the source is reflected again as a wave now traveling toward the load which appears as a ghost in the picture. The distance on the screen between the main image edges and the ghost edges is a function of the length of the coaxial cable and thus signal propagation delay in the cable.
Splitting the signal using a Y adapter results in the source being terminated in 75/2 or 37.5 ohms at the Y which reduces the signal level to 2/3 of normal and causes significant energy to be reflected back to the source. If the signal is properly terminated at the source and both receiving ends you will get a dark picture that otherwise looks OK but any differences between the impedance of the cables and the terminating impedance will cause reflections that bounce back to the Y where there is a major impedance miss-match which will cause signal energy to reflect back toward the receiving device.
Splitting an analog video signal (composite or component) is properly done by using an active amplifier with a 75 ohm input termination and a gain of two with a very low output impedance feeding two or more 75 ohm source terminating resistors. This results in no signal level loss and isolation between the signals feeding the down stream devices. That is how professional equipment works.
bunalz likes this.
Rory
Rory Boyce is offline
post #11 of 14 Old 12-18-2012, 07:27 AM
SAM64's Avatar
Liked: 78
No, half of it gets dropped across the source resistor.
SAM64 is offline
post #12 of 14 Old 12-18-2012, 07:56 PM
Rory Boyce's Avatar
That would be the case only if you are using the energy from the amplifier output as a reference point instead of the energy being sent on the coaxial cable. Obviously we are in the weeds here.
Rory
post #13 of 14 Old 12-19-2012, 04:19 AM
SAM64's Avatar
Liked: 78
No, not at all.
It's a simple series circuit. The source resistor is in series with the output, it forms a voltage divider with the load resistor, resulting in half the voltage across the load and half across the source resistor.
SAM64 is offline
post #14 of 14 Old 12-19-2012, 01:43 PM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
POWER transfer is MAXIMIZED and Reflections (SWR) are MINIMIZED when Load Impedance is "matched" to the Source Impedance:
http://en.wikipedia.org/wiki/Maximum_power_theorem
http://en.wikipedia.org/wiki/Impedance_matching
In Component Video interfaces, the resultant lower voltages can reduce brightness and change colors while reflections can blur the images with minor ghosting....depending on the length of the cable.
holl_ands is offline
Reply HDTV Technical
