Trouble getting one certain station - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-27-2012, 11:35 AM - Thread Starter
Countryboy74's Avatar
I just recently put up an antenna it is the RCA model #ant3036x. I was only able to get a few channels so I put the channelmaster 7777 preamp on it. Now I get all the channels I want except for channel 17.1. According to tv fool channel 17.1 is the exact same azimuth as some of the other channels I am getting yet I can't get a signal from 17.1.
I live almost 50 miles from the transmitters I am also down in a valley with a huge hill and lots of trees in the direction of the transmitters do I need to upgrade to a larger antenna?
Countryboy74 is offline
post #2 of 10 Old 09-27-2012, 12:12 PM
Otto Pylot's Avatar
Quoted: 1372 Post(s)
Liked: 858
How high up is the antenna? If you live in a valley with trees in the LOS that could be your problem. Did you install a rotor? Maybe you just need to tweak the direction a bit.
Otto Pylot is online now
post #3 of 10 Old 09-27-2012, 12:18 PM - Thread Starter
The antenna is about 25 feet high. No rotor because the stations I want are all in the same direction. I will try tweaking the aim some more.
post #4 of 10 Old 09-27-2012, 01:20 PM
Otto Pylot's Avatar
Liked: 858
25' from ground is pretty good. I think the recommended height is 30' but that's dependent on various factors (mine is 30' from ground). I have a rotor but rarely use for the same reason as you. However, it's nice to be able to move the antenna around if it gets moved a bit in a strong wind or I just want to see what else I can get. I too am about 50 miles from the towers but I have a dead-on, unobstructed LOS to them.
post #5 of 10 Old 09-27-2012, 02:26 PM - Thread Starter
Do you think a bigger antenna like say the winegard 8200u would help me? I just find it odd that i get the stations that according to tv fool have the same azimuth as 17.1 yet I can't even find a signal for 17.1. The azimuth is 269 for 17.1 and several of the other stations. I even get 22.1 which has an azimuth of 109.
post #6 of 10 Old 09-27-2012, 03:00 PM
Otto Pylot's Avatar
Liked: 858
The Winegard 8200u is very similar to my almost 30 year old Winegard that has been faithfully serving us for that length of time. I don't know if a bigger antenna would help or not. Maybe someone else can answer that one. Quite possibly 17.1 is a weaker station and is being overpowered by 66.1. I would see if there is a HDTV Local forum here for your location and see what others in your area have to say.
post #7 of 10 Old 09-27-2012, 03:53 PM
ProjectSHO89's Avatar
Quoted: 215 Post(s)
Liked: 112
Please post the link to your TVFool plot, not an illegible screenshot.
Most likely, you're experiencing a dead spot for that one particular frequency. Moving the antenna (or the trees) will likely change the reception.
ProjectSHO89 is online now
post #8 of 10 Old 09-27-2012, 04:09 PM
Otto Pylot's Avatar
Liked: 858
Click on the screenshot and it gets bigger so you can read it. Moving the antenna (via rotor or by hand) has been suggested.
post #9 of 10 Old 09-28-2012, 04:31 AM
Quoted: 215 Post(s)
Liked: 112
While the image gets bigger, it doesn't provide the ability to click on an individual line to see the path profile. That makes the screenshot to be of little value in analyzing the signal path.
post #10 of 10 Old 09-29-2012, 01:03 PM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
As mentioned in the sticky, ALL antenna help threads are to have a LOCATION in the title of the thread and the link to the TVFOOL report in the first post. Please REPOST following this convention and we'll see what we can do to help you. We're wasting time trying to figure out where you are.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Closed Thread HDTV Technical
