AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   HDTV Technical (http://www.avsforum.com/forum/25-hdtv-technical/)
-   -   Rec 709 VS sRGB and Adobe 98 (http://www.avsforum.com/forum/25-hdtv-technical/1432165-rec-709-vs-srgb-adobe-98-a.html)
Thebarnman 10-03-2012 02:22 AM
I'm just trying to figure out what one has the widest color space.
I don't care that sRGB is the internet standard or that Adobe 98 has a wider color space when compared to sRGB.
I'm simply trying to figure out if Rec 709 has a wider color space when compared to the other standards.
If Rec 709 is wider than the those two, then the question would be how does Rec 709 compare to Pro RGB?
DrewL 10-04-2012 01:03 PM
Rec.709 color space is basically identical to sRGB. Adobe RGB (1998) is wider than both.
http://www.sant-media.co.uk/wp-content/uploads/2010/06/cie.jpg
http://en.wikipedia.org/w/index.php?title=File:CIExy1931_Rec_2020_and_Rec_709.svg&page=1
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
