panasonic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2012, 08:38 PM - Thread Starter
j0hnnyyyy's Avatar
i have a panasonic gt50 and try connecting my external hd to it to watch movies but an error message comes up saying overload and it tells me to turn the tv off. once i turn it off and back on the tv says it doesnt have anything in its slot can someone please help. my external im using is the seagate for mac and pc
j0hnnyyyy is offline
post #2 of 4 Old 10-10-2012, 07:56 AM
sitlet's Avatar
The tv may require the hard drive to be formatted with FAT32, although I'm not positive on that model. But if you are getting an "overload" message, it's likely the hard drive requires too much power and the tv's usb port doesn't provide it. Does the hard drive have an external power supply?
sitlet is offline
post #3 of 4 Old 10-10-2012, 08:03 AM
ctdish's Avatar
Quoted: 73 Post(s)
Liked: 35
At a guess I would say that the dive is drawing too much power. If the drive is powered from the USB port like the small portable ones it is possibly overloading the 5 volts available from the TV. Try using a drive with an external power supply.
John
ctdish is online now
post #4 of 4 Old 10-10-2012, 09:44 AM - Thread Starter
j0hnnyyyy's Avatar
okay that may be it because i know when i plug it into my mac the hd is powered up by the mac.
Reply HDTV Technical
