Toshiba 65HT2U Power Supply Voltage Outputs - AVS Forum | Home Theater Discussions And Reviews
Old 10-31-2012, 03:23 PM - Thread Starter
jstiene's Avatar
Hi.
I have a Toshiba 65HT2U TV that I received with a cracked screen. When I plug it in, all I get is the GReen LED (Standby I assume). No response when pushing the power on button. I disconnected all cables from the power supply and measured 5 volts but no 24 volt outputs on any connectors. I have not done any troubleshooting in some time. Does there need to be a load on the PS in order to meaure the 24 volts or did I do it correct by simply disconnections all associated boards...AV,inverters,etc...
also, is there a schematic available somewhere for this particular TV?
Thanks in advance...Joe
jstiene is offline
Toshiba 65ht2u 65 Inches Lcd Tv 16 9 1080p 120 Hz
