Help with OTA Baton Rouge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2012, 10:22 PM - Thread Starter
TDI Derf's Avatar
So, do I point my antenna West?
Also, what might I expect from an ANT751 in the attic vs. mounted to the chimney?
TDI Derf is offline
post #2 of 3 Old 11-05-2012, 12:36 PM
mikepier's Avatar
Quoted: 16 Post(s)
You are close enough to the towers that the ANT 751 in the attic should be fine. The only issue I see on your chart is the CW network which is 52 miles away with 2 edge reception. If you don't care about CW, then you will be fine. Point the antenna towards the SW. You might have to find a sweet spot since some stations are a couple of degrees apart, but you should be fine since you are close.
mikepier is offline
post #3 of 3 Old 11-05-2012, 04:05 PM - Thread Starter
TDI Derf's Avatar
OK, thanks.
TDI Derf is offline
Reply HDTV Technical
