connecting TV antenna coaxial cable to existing cable box outisde my home. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-12-2012, 09:43 AM - Thread Starter
freeota's Avatar
Hi,
I am not very techy!, so please excuse my language!!
I have internet conection from my cable company, they have a box outside the house. I am planning to install a tv antenna just close to it and was wondering if I can connect my antenna coaxial cable to the cable box, so all the cable outlets in my home can receive OTA channels. Hoping that my broadband internet from cable will still work. see a picture of my cable box attached.
Is this possible ?
If yes, what are the parts I need to but, from where ? little bit of detail will help a lot!
appreciate any help.
freeota is offline
post #2 of 17 Old 11-12-2012, 10:26 AM
mikepier's Avatar
Quoted: 16 Post(s)
You cannot combine OTA signals with cable signals. Do you presently have any TV's or cable boxes in your home,, or do you just have internet?
If you only have internet, then you can run a new coax from the outside box connected to the white feed cable to wherever your cable modem is. Then connect your antenna to the existing black cable in the box, which will make all the cable outlets live. This is assuming your splitters are rated for at least 900-1000Mhz. Some of the older ones only go up to 550Mhz, which will block some OTA channels.
If you like you can post your tvfool results so we can get an idea of reception in your area. (Your address will not be shown).
mikepier is offline
post #3 of 17 Old 11-12-2012, 10:59 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Actually, you can combine them. You just won't be able to watch anything or use the internet. wink.gif
Cabal0 and Cableguy Greg like this.
CIAO!
Ed N.
egnlsn is online now
post #4 of 17 Old 11-12-2012, 12:24 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
To the OP. Post #3 was an attempt as a joke....
Why confuse the confused?
egnlsn likes this.
Ratman is online now
post #5 of 17 Old 11-12-2012, 04:24 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Yes, my post (#3) was just a joke.
CIAO!
Ed N.
post #6 of 17 Old 11-12-2012, 09:24 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
If you can help constructively, please do. Other-wise........
Otto Pylot is offline
post #7 of 17 Old 11-12-2012, 10:40 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by freeota View Post
Hi,
Is this possible ?
Some of the antenna frequencies will interfere with the HSI, which needs a clean ~855 MHz and ~40 MHz. I wouldn't do it.
domino92024 is offline
post #8 of 17 Old 11-13-2012, 03:55 AM
ProjectSHO89's Avatar
Quoted: 206 Post(s)
Liked: 109
Don't do it.
You must use physically separate coaxial cables for each service.
ProjectSHO89 is online now
post #9 of 17 Old 11-13-2012, 07:01 AM
kenglish's Avatar
Liked: 39
Combining them could also result in an FCC visit, unless the Cable Cops get there first! wink.gif
(Cable uses most of the spectrum, from about 5 MHz, all the way up to 800 or 1000 MHz. This overlaps not only the OTA TV channels, but every other service you can imagine. Combining will not only obliterate your Cable and Internet services, but will likely feed back in to the Cable system, and out the antenna.)
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #10 of 17 Old 03-17-2014, 12:36 PM
ngrider78's Avatar
I am in the process of running OTA HDTV from my attic to my cable box. Theoretically one should be able to disconnect the cable providers line-in so there is no interference/feedback. Once the cable providers line is not connected to the rest of the homes coaxial you should be able to use that same coaxial and connect the OTA cable to it. Am I wrong?
ngrider78 is offline
post #11 of 17 Old 03-17-2014, 01:25 PM
Ratman's Avatar
Liked: 1022
Try it and report back.
post #12 of 17 Old 03-18-2014, 06:23 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
If TV is the only thing you're going to be passing along that cable, then yes, you can use it fine. But, you were originally wanting to use the same cable for internet as well, which can't be done.
CIAO!
Ed N.
post #13 of 17 Old 03-24-2014, 05:32 AM
ziggy29's Avatar
If the cable is not connected -- that is, if the cable run to the house is disconnected from the wiring going into the house -- and you connect a TV antenna to the wiring going into the house (where the cable *used* to connect), it should be fine. But not with the cable line still connected.
ziggy29 is offline
post #14 of 17 Old 11-24-2015, 06:25 PM
Quoted: 35 Post(s)
Liked: 1
Folks I have a COX cable box outside my home. I used to have their service but I am no longer their customer. In that case if I connect a rabbit ear antenna output to the COX cable box, that should be OK ? If yes, then would I need an amplifier ?
infotalk is offline
post #15 of 17 Old 11-24-2015, 06:25 PM
Quoted: 35 Post(s)
Liked: 1
infotalk is offline
post #16 of 17 Old 11-24-2015, 07:45 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
As long as the COX cable is not physically connected from the drop line to the box, it's probably ok. We can't tell that because it is possible the drop line still has signal but equipment leased to you no longer has valid decryption keys.
The need for an amplifier depends on information you hadn't posted in this thread (e.g., signal strength, how much the signal gets split up).
My very humble setup:
Spoiler!
Mark12547 is offline
post #17 of 17 Old 12-01-2015, 02:31 PM
istandalone's Avatar
Liked: 2
length of coax and How many splits etc. good luck could be a pain if you have to test the existing coax for shorts.
istandalone is offline
Reply HDTV Technical
