Maximum Antenna on a J-Mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-21-2012, 08:06 AM - Thread Starter
sregener's Avatar
I'm looking at putting up a Winegard 8800 antenna + preamp + Rotor on my roof, and am thinking a J-mount is a cheap and simple way to go. But I can find no technical details about maximum windload for these things, or maximum recommended antenna size. I'm thinking that a dish, being a large, solid object, would have much higher wind load than a large bowtie UHF antenna, but I'm willing to be wrong. Anyone have any advice or specific information about J-mounts for antennas?
sregener is offline
post #2 of 2 Old 11-24-2012, 08:31 PM
tyromark's Avatar
A rotor will be too much weight for a J-mount. I used an existing J-mount for a "turnstile"-type FM antenna once and it seemed successful (no movement, no roof leaks) and if the bowtie antenna were the same weight as that, no problem. Rotors, though, are heavy.
tyromark is offline
Reply HDTV Technical
