trying to hookup rocketfish wireless headsets to vera tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-17-2012, 07:08 PM - Thread Starter
modell's Avatar
vera tv model tc-l32c12-k
I bought digital to analog audio convert
y cable
toslink to toslink 6ft
toslonk fits in the back of the tv digital audio out put
And i hooked up to the digital to analog audio convert
all looks good,But still not working
with my rocketfish wireless headssets
Much help would be great
Thank you
god bless
modell is offline
post #2 of 13 Old 12-17-2012, 11:30 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
y cable
Thank you
god bless
Are you listening to Dolby encoded audio from HD or other ATSC signals? If so, does your converter decode Dolby?
domino92024 is offline
post #3 of 13 Old 12-18-2012, 02:03 AM - Thread Starter
modell's Avatar
I dont know if it decodes dolby,also do i need a coaxial cable,and a mini digital cable,
Thank you for your reply.
modell is offline
post #4 of 13 Old 12-18-2012, 02:18 AM - Thread Starter
modell's Avatar
Converter box model is
Cx_tos-anlg
modell is offline
post #5 of 13 Old 12-18-2012, 08:19 AM
ctdish's Avatar
Quoted: 67 Post(s)
Liked: 35
It appears from the user reviews on Amazon that the box does not support Dolby decoding. Some TV allow the TOS audio to be converted to 2 channel PCM. This would be done from a menu setting on the TV. My Panasonic TVL55ET5 does not seem to support this.
John
ctdish is online now
post #6 of 13 Old 12-18-2012, 08:58 AM - Thread Starter
modell's Avatar
Thank you John.
Which covert box should i buy..on amazon..
Ford
modell is offline
post #7 of 13 Old 12-18-2012, 10:26 AM
ctdish's Avatar
Quoted: 67 Post(s)
Liked: 35
post #8 of 13 Old 12-18-2012, 10:33 AM - Thread Starter
modell's Avatar
Will this also work...it is much cheaper..
FiiO D3 Digital to Analog Audio Converter With Micca 6ft Optical Toslink Cable - 192kHz/24bit Optica...
Thnak you for your help..
Ford
modell is offline
post #9 of 13 Old 12-18-2012, 01:48 PM
Quoted: 126 Post(s)
Liked: 216
Ford
Note that the product description for that model states the following:
"NOTE: The FiiO D3 only supports PCM audio signals and does not support Dolby, DTS, or other surround sound signals. Therefore, it is important that the digital audio output of your device defaults to or can be set to PCM/LPCM output. Otherwise the sound output will be noise/static."
http://www.amazon.com/D3-Digital-Converter-Optical-Toslink/dp/B005K2TXMO/ref=sr_1_2?ie=UTF8&qid=1355863300&sr=8-2&keywords=fiio+d3
Does that answer your question?
post #10 of 13 Old 12-19-2012, 07:35 PM
bmurray716's Avatar
y cable
Thank you
god bless
Unless I am missing something obvious the TV has a analog out which you should connect to the wireless headphone base. Change the audio settings on the tv to analog out and that should do it.
LG 42LB5600, Sony BDP-S590, Pioneer VSX-516, JBL LX22, Definitive Technology ProCenter 1000, Polk DSWPro400, Polk OWM3, Logitech Squeezbox Classic, Squeezebox Radio
bmurray716 is offline
post #11 of 13 Old 12-20-2012, 01:57 PM
ctdish's Avatar
Quoted: 67 Post(s)
Liked: 35
Unfortunately many TV are being made with no analog output. This one only seems to have a digital audio output.
John
post #12 of 13 Old 12-20-2012, 07:19 PM
tylerSC's Avatar
Quoted: 724 Post(s)
Liked: 166
John
Some LCD/LEDs still have analog audio out, but the newer plasmas do not. I'm sorry they have eliminated the RCA audio outputs.
tylerSC is online now
post #13 of 13 Old 12-21-2012, 10:31 AM
Possumgirl's Avatar
Liked: 58
The connections the OP listed in his first post should work, providing he is not trying to listen to audio from the TV's internal tuner. Panasonic TVs output 2 ch. stereo from source devices connected to the TV, but for the internal tuner they output DD5.1 (when available). There is no setting to force PCM out for the tuner's audio.
Digital optical is the only audio out on this TV.
OP should check the Viera settings on his TV to be sure he has speakers set to "external".
Possumgirl is offline
Reply HDTV Technical
