Problem using splitter/amplifier with FiOS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-20-2012, 06:49 AM - Thread Starter
hvtopiwala's Avatar
ok so we installed a centralized media closet with all 4 Verizon Fios cable boxes. I took a drop from one of the rooms and moved it into the media closet. i then tried using a 4 way digital spliter....all the TV's have picture, but none of them have a Guide or on demand as each box isnt getting an internet connection. So i removed the 4 way splitter and installed the drop direcftly to one box and it works fine, get the guide/VOD and everything....so i thought it might be a weak signal so i purchased a 4way amplifier....and same problem! is there anything i can do to split this drop 4 ways? oh the wire that i dopped into the media closet is coming out of a 2way splitter from our Gym (the gym gets the guide/VOD and evertyhing else too)...so the problem lies with splitting it in the media closet. i also tried just splitting it 2 ways and i had the same problem in the closet. i hope this all makes sense!
hvtopiwala is offline
post #2 of 9 Old 12-20-2012, 07:16 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
You need to be sure your amps are bidirectional and have active return path for video on demand and internet features to work. Otherwise they will be blocked. Both Motorola and PCT/Channel Master make various versions of these dist amps that work very well. But just make sure you select the right one. And if you add passive splitters, it could be a possibility they are also blocking the return path signal.
tylerSC is offline
post #3 of 9 Old 12-20-2012, 07:34 AM - Thread Starter
hvtopiwala's Avatar
im using this AMP now and same problem (its bi-directional and im using Terminators on the un-used ports):
http://www.amazon.com/8-Port-Bi-Directional-Amplifier-Splitter-Booster/dp/B000WDR94U/ref=sr_1_1?ie=UTF8&qid=1354745784&sr=8-1&keywords=8+port+coaxial+amplifier
Also the passive splitter i tried using works fine at the original split and i get all VOD/internet features to work...its just as soon as i split in that media cloeset i lose everythin but the picture...
post #4 of 9 Old 12-20-2012, 12:23 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Looks like that PCT version may have passive return, and for video on demand you may need an amp with active return.
tylerSC is offline
post #5 of 9 Old 12-20-2012, 12:25 PM - Thread Starter
hvtopiwala's Avatar
can i get one of those locally at like radioshack? is the signal drop so severe that even a 2 way passive splitter didnt work?
post #6 of 9 Old 12-20-2012, 12:32 PM - Thread Starter
hvtopiwala's Avatar
post #7 of 9 Old 12-21-2012, 08:52 AM - Thread Starter
hvtopiwala's Avatar
^will that work?
post #8 of 9 Old 12-21-2012, 01:15 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Radioshack amps are not always recommended, but this model seems to get good reviews. So you could always give it a try and return it if necessary.
tylerSC is offline
post #9 of 9 Old 12-21-2012, 01:41 PM - Thread Starter
hvtopiwala's Avatar
ok will do smile.gif do you know if its active return or passive return?
Reply HDTV Technical
