Can I connect a PC to a smart TV via wifi? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-24-2012, 08:35 PM - Thread Starter
little.dread.1's Avatar
Hi, I currently connect my PC in my living room via a 25 mtr HDMI Lead to A Sony 42" TV in my bedroom as a secondary monitor & operate the PC with a bluetooth keyboard or android device via wifi. I'm considering upgrading the Sony to a PANASONIC VIERA TXL42E5B Smart TV,
My question is would I be able to stream my PC to this TV via wifi using the optional wifi dongle instead of using the HDMI lead?
little.dread.1 is offline
post #2 of 9 Old 12-24-2012, 11:52 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Probably not.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 9 Old 12-25-2012, 05:28 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
Sending a HD stream via RF with consumer devices is pushing things.
You stated your HDMI cable is 25 "mtr" as in meters???
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #4 of 9 Old 12-25-2012, 10:07 AM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1022
That's what I was thinking. That's over 75'!
Otto Pylot is offline
post #5 of 9 Old 12-25-2012, 12:17 PM - Thread Starter
no sorry it's actually it's my sky eye rf lead that is 25 meters the HDMI only 10 - 15 meters..
post #6 of 9 Old 12-25-2012, 12:45 PM
Super Moderator
DrDon's Avatar
Quoted: 1261 Post(s)
Liked: 2430
Stick with the way you have it. AFAIK, smart TVs do not have the capability to be used as a Wi-Fi display, anyway. They simply have a collection of streaming and web apps that fetch information off the 'net.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #7 of 9 Old 12-25-2012, 01:03 PM
Otto Pylot's Avatar
Liked: 1022
That's still 30' - 45'. Most passive High Speed HDMI cables are good to about 25'.
post #8 of 9 Old 01-13-2013, 05:15 AM - Thread Starter
Got a Panasonic TX-P50UT50 in the end which was far too big for bedroom use, so I have now wall mounted the 42" in the bedroom still using the old HDMI lead to connect to the PC.
As I couldn't remember the exact length of the HDMI lead I originally used in my set up, I've double checked my Amazon account from whom I had bought the cable. The HDMI lead is actually 20 meters coupled with a Display port to HDMI adapter connected to my PC via an ATI HD 6870 Graphics card. The Display port adapter supports HDMI leads up to 15 meters officially but works perfectly with my 20 meter cable.
post #9 of 9 Old 04-21-2013, 10:18 AM
Frank Touchston's Avatar
Hi mate, yes you can connect your pc to tv over wifi.
It's called WiDi, your new TV should support it , if your pc doesn't support it then you can buy a WiDi dongle, £50 quid.
Frank Touchston is offline
Reply HDTV Technical
