HD TV and charter cable - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 05:36 PM - Thread Starter
dtodd38's Avatar
Just bought my parents an HD digital LCD tv, it does have a digital tuner built into it.
Tried to hook the cable directly to the tv and ran a channel search. It did not find any channels.
Do I need to get a box from charter cable for the tv to be able to pick up channels?
dtodd38 is offline
Old 12-30-2012, 06:45 PM
sitlet's Avatar
It did not find ANY channels? It should have at least found the analog channels, unless Charter has gone all digital in your area, in which case you would have already had a box.
Second, a digital tuner can mean two things: OTA or QAM. QAM is the hd channels your provider sends "in the clear", usually just the local broadcast channels. For anything else, like ESPN, HBO, etc, you would need an HD cable box (and pay for the HD package of course). For OTA, you would need an antenna.
sitlet is offline
Old 12-30-2012, 07:08 PM - Thread Starter
dtodd38's Avatar
Thanks, I am pretty sure they need the box from the cable company. This line did not have a box previously.
dtodd38 is offline
Old 12-31-2012, 08:35 AM
sitlet's Avatar
If the previous tv did not have a box, this new tv should get the same channels, assuming it has an NTSC tuner, which 99% of tv's have.
sitlet is offline
Old 12-31-2012, 03:45 PM - Thread Starter
dtodd38's Avatar
Talked to the cable company today. They should be able to hook right into the TV. Going to make sure that it is set on the correct input. If this does not work the cable company is going to check the line. Thanks for your help.
dtodd38 is offline
Old 01-02-2013, 01:56 PM
gbynum's Avatar
Quoted: 25 Post(s)
Charter is a multi-location outfit, so your location would help ... most of us put it in our profile. In upstate SC, we get the 6 networks in HD, and some 85 additional channels (38 digital, 53 analog total) with the cable connected directly to the TV. Some analogs are also on the digital; there are probably 60 unique channels total.
gbynum is offline
Old 02-13-2013, 11:47 AM
jstarling82's Avatar
I have Charter internet, and multiple people with the company have told me they no longer provide Clear QAM, at least in the Atlanta area.
jstarling82 is offline
