HD signal to projector question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-03-2013, 03:38 PM - Thread Starter
marxus's Avatar
This is kind of a very specific situation and after an hour of googling I could not find much.
Goal:
Watch HD over the air on basic local stations on my projector (Playoff game, woo!). I have no cable provider and everything I watch streams over my PC, gaming consoles, or is physical media/pre-loaded. NFL doesn't do live streaming so that is out.
Setup:
Optoma GT700 projector which has the following inputs: HDMI, PC Input, RS-232, S-video, r/w/y
I don't currently have a receiver or home theater audio setup it is just an HDMI splitter, my projector, consoles, and PC. Eventually I would like the home theater but that is for another thread. Is there any simple or cheap (under $50) solution to just get those basic TV stations for the rare times when I want to watch live TV? Antenna that could plug right in, simple converter box (I have a basic VHS/UHF ant)? I found some USB PC tuner and I could just make the projector the monitor but those seem like they are a little pricey.
thanks,
Marxus
marxus is offline
post #2 of 5 Old 01-03-2013, 08:13 PM
Colm's Avatar
Liked: 94
Well, you could buy a used ATSC convert box on eBay under $50.
Colm is offline
post #3 of 5 Old 01-04-2013, 03:07 AM
ProjectSHO89's Avatar
Quoted: 249 Post(s)
Liked: 120
A standard converter for $50 is going to be standard def. From examples I've seen, it looks like crap on an HD projector.
There really aren't that many inexpensive options. You can go the internal or USB tuner route, but you're going to have to deal with the PC aspect of the equation.
After that, stand-alone HD ATSC converters can be bought for $100+. The KWorld SA295Q is about the least expensive of the bunch.
ProjectSHO89 is offline
post #4 of 5 Old 01-04-2013, 11:41 AM
oktoberrust11's Avatar
Quoted: 70 Post(s)
Liked: 38
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #5 of 5 Old 01-06-2013, 06:58 PM
pacofortacos's Avatar
Liked: 24
Something like this would work for you.
.ebay.com/itm/HDTV-HD-ATSC-Tuner-PVR-and-FTA-HD-EBOX-Stealth-HD-w-remote-/170970949263?ssPageName=ADME:L:LCA:US:1123
I use a box similar to it, a sonicview 8000HD - in fact I use 3 of them for HD recording/watching - though my tv has a built in tuner.
pacofortacos is offline
Reply HDTV Technical
