Composite inputs and closed captioning - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-05-2013, 08:12 PM - Thread Starter
opus312's Avatar
For those who are hearing-impaired, technology is going backwards. Using digital connections, captions are often garbled or non-existent. It used to be easy to access the TV's analog captioning through S-Video or composite video connections, but those are few and far between these days. Looks like the only way to get adequate composite video inputs is through a receiver. No simple sound bars for us. Everything seems to be way more complicated (and more expensive) when captions are of primary importance. Sigh...
Steve
opus312 is offline
post #2 of 10 Old 01-06-2013, 11:36 AM
SAM64's Avatar
Liked: 78
If you mean downconverting an HD signal to SD results in garbled captions, it's due to the poor downconversion in your equipment.
SAM64 is offline
post #3 of 10 Old 01-06-2013, 12:29 PM - Thread Starter
opus312's Avatar
Trying to watch an HD program through an HDMI or component connection, the captions are often useless - so I need to switch to an analog connection (thus losing the HD picture) and use the TV captioning instead of the Tivo.
opus312 is offline
post #4 of 10 Old 01-06-2013, 02:28 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
I use HTPCs and a HDHomeRun Prime to tune channels and Windows Media Center does a pretty good job of displaying captions on both HD and SD programs so I know they can be displayed from HDMI ports. I am surprised though the the caption options are greyed out on my HDMI inputs.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 10 Old 01-06-2013, 02:58 PM - Thread Starter
opus312's Avatar
HDMI displays captions, but the quality is extremely variable. Often much better through a composite connection, although the picture itself is obviously worse. Doesn't seem to be any good solution to this...
opus312 is offline
post #6 of 10 Old 01-07-2013, 08:41 AM
SAM64's Avatar
Liked: 78
HDMI doesn't carry closed captions, so the data is decoded and overlayed by the source device (Tivo?)
SAM64 is offline
post #7 of 10 Old 01-07-2013, 09:58 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
If a local station isn't presenting acceptable closed captions, notify the station. This is an FCC requirement.
Back in the old days a local HDTV station occasionally switched to the network's SD feed because the captions weren't working on the HD feed. One station even had to extract the captions from the SD feed because the network simply didn't provide them on their HD feed.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
post #8 of 10 Old 01-07-2013, 11:21 AM - Thread Starter
opus312's Avatar
That would keep me pretty busy, it's almost universal on digital feeds. Even where the captions are legible, they're often so delayed as to be useless (60 Minutes, for example)
opus312 is offline
post #9 of 10 Old 01-08-2013, 12:26 PM
Milt Frankel9's Avatar
i have been using a rng 110 cable box with hdmi out to hdmi in to tv for 2 years.captions work fine.
milt
Milt Frankel9 is offline
post #10 of 10 Old 01-09-2013, 05:53 AM
SAM64's Avatar
Liked: 78
As mentioned, in the part you quoted, that's because your cable box is overlaying the captions, not the tv.
SAM64 is offline
Reply HDTV Technical
