AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   HDTV Technical (http://www.avsforum.com/forum/25-hdtv-technical/)
-   -   Can I Wirelessly Connect Desktop PC to HDTV (i.e. Via HDMI Wireless)? (http://www.avsforum.com/forum/25-hdtv-technical/1450689-can-i-wirelessly-connect-desktop-pc-hdtv-i-e-via-hdmi-wireless.html)
Scott_111 01-09-2013 02:58 AM
I have a Dell Inspiron 560s desktop which I would like to connect to my HDTV (Vizio VT420M) via wireless HDMI. The Netgear PTV2000 PC to TV wireless display adapter looks as if it does exactly what I want, i.e. have my TV displaying the same information that my computer monitor is displaying. The problem is that my PC is a desktop and not a laptop so it does not have WiDi capability that laptops have and which it would need to communicate with the Netgear adapter.
Is there any way to accomplish what I am trying to do….such as getting a stand-alone wireless adapter for the PC and do it without spending a fortune? Also, would a wireless HDMI PC to TV connection of the type I am describing include audio also? The product descriptions are confusing since they discuss video display only but it would make no sense to connect a PC to a TV in this manner without having the audio transmitted as well. Thanks in advance for any feedback.
Ratman 01-09-2013 06:15 AM
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=8087&CAWELAID=1329456162&cagpspn=pla&gclid=CL_Z3qSt27QCFUOK4AodJlUAIw
DrDon 01-09-2013 09:41 AM
9 Attachment(s)
It's not always there, but Costco has the same thing for about $50 less. Almost bought one. Wish I had. Hasn't been at the store my last couple trips.
Scott_111 01-09-2013 07:26 PM
Thanks for the responses. The Monoprice is a little steep but it looks as if it does what I am looking for. I will also look around for cheaper prices such as the one mentioned at Cosco.
Update - 01/10/13
In case anyone is interested, I have discovered that Dell does indeed provide the type of wireless display capability I am looking for not just on laptops but on *some* desktops as well (desktop must be based on 3rd generation Intel Core Processor). It basically requires just a download of drivers and other software from Intel's web site and will only work on Windows 7 and 8. Obviously it still requires a wireless adapter on the TV just as it would when using a laptop.
http://www.intel.com/support/wireless/sb/CS-033372.htm
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
