FIOS "not supported" msg, intermittent signal loss on one set only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-09-2013, 12:59 PM - Thread Starter
dagger666's Avatar
It seams after watching FIOS for awhile the screen starts to have faint black lines running thought it before it goes off with the message NO SINGLE or NOT SUPPORTED on the screen eek.gif. It goes on and off then off for up to 30 seconds and then comes back on mad.gif. It might do this couple of times a day but never on other TV just mine. Could it be the FIOS box down stairs cause I had the regular FIOS box on the TV changed or is it something with the TV and Component 1 connection confused.gif? It will also display Component 1 on the black screen sometimes.
dagger666 is offline
post #2 of 2 Old 01-09-2013, 01:03 PM
Super Moderator
DrDon's Avatar
Quoted: 1200 Post(s)
Liked: 2355
Title edited to make more specific.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Reply HDTV Technical
