Coaxial to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-11-2013, 05:09 PM - Thread Starter
gbh84's Avatar
Hi everybody,
I bought a Sony 3D Display and I would like to connect it to the coaxial cable for SD TV. The sony has only HDMI inputs, so I was wondering if there exist a converter.
A guy from steren sold me a HD tuner box, but it only scans the digital channels, in my case only music (I only have SD channels from my cable company) .
Thaks a lot for your help!!
GBH
gbh84 is offline
post #2 of 9 Old 01-11-2013, 10:55 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by gbh84 View Post
Hi everybody,
Please give the model number of this Sony TV that doesn't have a coaxial input. Might this be a computer monitor?
You would need a QAM tuner/demodulator, then a HDMI circuit of some sort...LIKE A CABLE STB!
domino92024 is offline
post #3 of 9 Old 01-12-2013, 08:33 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
If it's going to be connected to a CATV source. Otherwise, an ATSC STB would be needed, but it would have to be an HD one to get an HDMI output.
CIAO!
Ed N.
egnlsn is offline
post #4 of 9 Old 01-12-2013, 09:51 AM
Super Moderator
DrDon's Avatar
Quoted: 883 Post(s)
Liked: 1753
Sounds like that's what the OP is trying to do. He has basic cable, but either all of the QAM signals are encrypted or there are traps on his line limiting him to analog only. Sounds like he was sold a QAM tuner and a scan only picked up the music channels.
IF so, then the best thing to do with cable is to get the cable box. He could also check his city's thread in the Local Reception section to see what his particular cable company is doing w/r/t QAM.
Otherwise, it's antenna time.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #5 of 9 Old 01-12-2013, 10:30 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
There's also the Clear QAM finder on the SiliconDust website. As for an ATSC, NTSC, QAM tuner with HDMI out take a look at whatever Magnavox/Phillips PVR is the current model (http://www.avsforum.com/t/940657/magnavox-537-535-533-515-513-2160a-2160-2080-philips-3576-3575/0_40).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 9 Old 01-12-2013, 02:19 PM
Quoted: 126 Post(s)
Liked: 216
Well, since he said "...from my cable company...", I assumed cable. wink.gif
post #7 of 9 Old 01-12-2013, 06:39 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Ah, I missed that part in the parentheses.
CIAO!
Ed N.
egnlsn is offline
post #8 of 9 Old 01-14-2013, 10:50 AM - Thread Starter
gbh84's Avatar
Thanks guys!!
The Sony 3D display is meant for Play Station.. I guess that's why it doesn't have a coaxial input.
I've been checking and I think the easiest solution is changing to an antenna company..
gbh84 is offline
post #9 of 9 Old 01-14-2013, 11:23 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
why not get a settop box from your cable provider $5 per month although some provide a free option. Also you could get a TiVo and cable card usually around $2 per mo. What is an Anntena company? Just buy a anntena from store no monthly charges but also no ESPN and such.
RollTide2011 is offline
Reply HDTV Technical
