Where can I get a "stub mast" for my eagle aspen antenna rotator? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-13-2013, 08:58 PM - Thread Starter
simplyme's Avatar
Hi, I'm new to the forum and new to OTA HDTV. Looking at the Eagle Aspen Rotator, the instructions indicate I should attach the antenna (a ClearStream2 in my case) to a "stub mast" (short 12" mast I'm supposed to get from somewhere). The stub mast will then be attached to the rotator and the rotator will be affixed to a "fixed mast" (I'm supposing my ClearStream2 J-mount). Anybody know where online can I buy the "stub mast" required by the aspen rotator? I really didn't want to pay the price of an extension I found on antennasdirect (almost $40) only to take a hacksaw to it.
simplyme is offline
post #2 of 8 Old 01-13-2013, 11:38 PM
Colm's Avatar
Liked: 94
Well, if you were using a 10' mast, you could just cut off the top foot. Otherwise, a piece of 1" EMT conduit will do the job. Of course, you may have to buy 10' of it if you go to a home improvement store. Still, it would only be about $7.
Colm is offline
post #3 of 8 Old 01-14-2013, 04:02 AM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
Do not mount the rotor on that 20" J-mount, it's not strong enough.
ProjectSHO89 is offline
post #4 of 8 Old 01-15-2013, 12:00 PM - Thread Starter
simplyme's Avatar
Thanks Colm for the advice...hadn't considered this, but i'll look into it.
simplyme is offline
post #5 of 8 Old 01-15-2013, 12:07 PM - Thread Starter
simplyme's Avatar
Thanks for the response; I don't expect the entire length (j-mount + rotator + stub mast + antenna) to be taller than 4 ft. Is it because of the weight of the rotator that you're saying this? The ClearStream2 is also pretty lightweight.
simplyme is offline
post #6 of 8 Old 01-17-2013, 04:48 AM
mikepier's Avatar
Quoted: 16 Post(s)
I know Radio Shack and Lowes has 5 foot masts.
mikepier is offline
post #7 of 8 Old 01-17-2013, 05:48 AM
Quoted: 211 Post(s)
Liked: 110
Yes, the antenna is lightweight but the rotor is not.
post #8 of 8 Old 02-09-2013, 06:15 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
You can also try larger EMT (electrical) conduit. Lengths less then 5'. More than that, you will need guy wires which you should have for any mast. wink.gif
There is a dedicated thread for the rotor here;
http://www.avsforum.com/t/840847/eagle-aspen-rotr100-diseqc-antenna-rotor
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Reply HDTV Technical
