digital combination of HDTV signals? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2013, 05:06 PM - Thread Starter
ivo welch's Avatar
does anyone make an external antenna combination device? after all, HDTV is all digital. so why not sample 2 to 30 different antennas to determine the best guess at what the individual bits are?.
this might even change the current art of guessing antennas into something that is less sensitive.
ivo welch is offline
post #2 of 4 Old 01-20-2013, 05:46 PM
Thread Ender
WS65711's Avatar
Quoted: 491 Post(s)
Liked: 328
The radio waves haven't changed. The laws of physics haven't changed. Only the transmitted data is different. The transmission method is the same as its always been.
egnlsn likes this.
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 4 Old 01-20-2013, 06:14 PM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
Antennas don't care what is on the carrier, they just care about the carrier. If it'll pick up a signal, that's all it cares about. In my area, I can literally put up a coat hanger and get most of my local channels, including full 1080i.
CIAO!
Ed N.
egnlsn is offline
post #4 of 4 Old 01-21-2013, 10:51 AM
retiredengineer's Avatar
Quoted: 35 Post(s)
Liked: 24
It's possible to do what you asked if you can afford it. You need 2 to 30 different HDTV receivers, all tuned to the same RF channel and a processor to do m-out-of-n processing of the outputs in real time to determine which of the eight levels is being transmitted and output the corresponding 3-bits.
retiredengineer is offline
Reply HDTV Technical
