Element tv shutting it self off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-22-2013, 11:00 AM - Thread Starter
swerve12's Avatar
I have an element tv that randomly turns it self off when hdmi is connected or coax. Sometimes it will be a few mins sometimes it 3 or 4 hrs, if I disconnect all inputs and just play blue screen it's fine. Any ideas?
swerve12 is offline
post #2 of 4 Old 01-22-2013, 07:35 PM
ctdish's Avatar
Quoted: 66 Post(s)
Liked: 35
The most likely guess if that the TV is broken. If it's under warranty get it taken care of by the seller or manufacturer. If you bought it with a credit card the warranty period may be extended by the credit card company. Diagnosing and fixing things today, unfortunately often costs more than buying a new TV, especially with bottom of the line TVs.
That said did you check if the TV has any programmable timers that have been started. Also find and cover with opaque tape the small window on the front of the TV that allows it to see the signal from the remote. This will rule out interfering inferred signals shutting the TV down.
John
ctdish is offline
post #3 of 4 Old 01-23-2013, 08:29 AM
jimboy's Avatar
jimboy is offline
post #4 of 4 Old 01-23-2013, 10:31 AM
Super Moderator
DrDon's Avatar
Quoted: 871 Post(s)
Liked: 1730
Please repost in the proper section. Thanks.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Closed Thread HDTV Technical
