Best way to watch MKV on TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2013, 12:12 PM - Thread Starter
lordbodom's Avatar
Hi,
I recently picked up a LG 47LM4600 3d tv. i want to watch movies off my drive but the audio is not supported as most MKV are DTS. i can convert to AAC, but that takes time. I was wondering if there was a better way to be able to watch these on my TV?
I have both a PS3 and an Xbox 360. i tried streaming the PS3 from my computer but it is way too laggy. Im just trying to see if there is a quicker solution than having to convert everything to AAC.
lordbodom is offline
post #2 of 6 Old 01-24-2013, 01:17 PM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
Not sure what you mean by "most MKV files are DTS." MKV's just a container. You can put whatever audio and video you want in there. If you're creating your own MKVs, then just use an audio codec the TV will play.
Or go to our HTPC section and build a box that'll do everything. That's what I did.
Cabal0 likes this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 6 Old 01-26-2013, 02:33 PM
pacofortacos's Avatar
Liked: 24
Do you have a receiver/surround? If so a bluray or other player should play it and send the audio to the receiver to decode and play the audio.
pacofortacos is offline
post #4 of 6 Old 02-09-2013, 06:01 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #5 of 6 Old 02-09-2013, 07:23 AM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Ratman is online now
post #6 of 6 Old 02-12-2013, 05:31 AM
SxDx's Avatar
I use a Roku with an free app called Plex to view MKV's on my tv.
SxDx is offline
Reply HDTV Technical
