Need Indoor Antenna for Chicago for CBS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-25-2013, 11:55 AM - Thread Starter
paulsiu's Avatar
I am currently living in a Suburb about 20 miles Northwest of Chicago. All of the stations broadcast out of Chicago,so they are all in one direction. Antenna web suggest that I use either yellow or green for Antenna types.
I am currently using a DB2 and the reception is good for most parts, some of the channels are better than others. However, the only channel I can't seem to get is CBS, because it is a VHF channel 2. I have tried attaching some rabbit year, but can't receive anything.
I am thinking of getting a Winegard SS3000, mostly because it's directional and because its got VHF capability. What do you think. Do you think it will work?
Paul
paulsiu is offline
post #2 of 5 Old 01-25-2013, 04:57 PM
ProjectSHO89's Avatar
Quoted: 210 Post(s)
Liked: 110
Rabbit ears and a UVSJ should fix it if it is even fixable, VHF reception indoors often just doesn't work.
ProjectSHO89 is online now
post #3 of 5 Old 01-25-2013, 08:33 PM
Rammitinski's Avatar
No.
If it does at all, it won't be anywhere near reliably.
Rammitinski is offline
post #4 of 5 Old 01-25-2013, 11:56 PM
dave73's Avatar
Paul
If you're insistant on an indoor antenna, good luck even trying to get WBBM-TV. Not many people can get VHF reception reliably indoors (VHF-LO is impossible with indoor antennas). You might be lucky if you can get the Antennacraft Y5-7-13 antenna to work indoors. Someone on here from 2 or 3 years ago tried that antenna in an apartment in Hammond, IN, & was lucky to get WBBM-TV with it, in the apartment. That's the only suggestion you could try. The other thing would be to try the rabbit ears outside.
dave73 is offline
post #5 of 5 Old 01-26-2013, 12:34 PM
rabbit73's Avatar
Quoted: 399 Post(s)
Liked: 159
Paul:
Please post a link to your tvfool report. You will find the link in bold type near the top of the report. Your exact address will not show.
If you live near Elk Grove Village, CBS WBBM-TV is NOT on real channel 2, it is on VHF-high channel 12; 2.1 is the virtual channel number, not the real channel number that is used for transmission. The real channel number determines what antenna is needed.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda57ec34fedc
The DB2 is primarily for UHF. A simple test to try would be a folded dipole for CH12 and a balun combined with your DB2 with a UVSJ as previously suggested. If the folded dipole doesn't have enough gain for CH12, because of the buildings in the way, then you will need to try a VHF-high (7-13) antenna, like the AD C5 which comes with its own UVSJ:
http://www.solidsignal.com/pview.asp?p=c5&d=antennas-direct-c5-clearstream-5-high-gain-digital-vhf-tv-antenna-(clearstream5)
The twin lead folded dipole would be about 27 inches long from end to end using the formula 5540 divided by the frequency in MHz (207).
http://hf-antenna.com/003/ fig 2
ATTACHMENT=66678]folded dipole.JPG (14k. JPG file)[/ATTACHMENT]Paul:http://users.wfu.edu/matthews/misc/dipole.html
http://www.google.com/search?q=twin+lead+folded+dipole&hl=en&tbo=u&tbm=isch&source=univ&sa=X&ei=-zEEUcQlkbXRAafIgLAB&sqi=2&ved=0CDQQsAQ&biw=997&bih=574
If you have trouble finding 300 ohm twin lead, you can cut down a Radio Shack FM antenna at each end. Don't forget to allow a little extra at the ends to short the wires together.
http://www.radioshack.com/product/index.jsp?productId=2062691
If messing with twin lead is tedious, you can make the folded dipole out of heavy gauge copper wire like #8 and attach it to a piece of plastic like Lexan. This could be mounted above your DB2.
folded dipole_1.JPG 17k .JPG file
Name:	folded dipole_1.JPG
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
Reply HDTV Technical
