OTA signal doesn't work when outer conductor makes contact - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-26-2013, 04:16 PM - Thread Starter
BnLd's Avatar
I recently bought a house with an antenna in the attic that I would like to use to receive Over the Air programming. The antenna is connected to a wall jack in my family room. My TV works when only the connector's inner conductor is inserted into the jack, but if the threaded portion of the connector contacts the threaded portion of the jack I loose signal.
Does anyone have an idea of what is wrong, and what I can do to fix it?
BnLd is offline
post #2 of 17 Old 01-26-2013, 04:19 PM
gregzoll's Avatar
Liked: 33
Bad connectors on the coax. You really need to use the Compression fittings, not the screw on ones, for the coax. That means going from that plate all the way to the antenna and replace the ends.
gregzoll is offline
post #3 of 17 Old 01-26-2013, 04:58 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Also, make sure that the center conductor of the coax to your TV is not W-A-Y too long. In the picture it kinda looks like it's longer than it needs to be... and it's impossible to tell from the picture just how much of the center conductor is already inside the jack . . .
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #4 of 17 Old 01-26-2013, 06:36 PM
holl_ands's Avatar
Quoted: 439 Post(s)
Liked: 182
With JUST the center conductor connected, there is probably some sort of unintended connection to the
OUTSIDE of the coax, probably due to a short in the coax or one of the connectors. With the Balun (or
antenna) in the attic disconnected, use an ohm meter to check for a short circuit between the coax center
conductor and the outer shield. To find the short, inspect each connector, looking for a stray shield wire.
And it's also possible that the antenna isn't correctly connected and the coax is acting as an antenna,
perhaps from capacitive coupling between the outer shield and the unterminated inner wire.
BnLd likes this.
holl_ands is offline
post #5 of 17 Old 01-27-2013, 08:56 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Those aren't twist-on fittings. They were made by Raychem (EZF connector) and were the immediate predecessor to the compression fitting. They were really popular in the '90s.
Could be a center conductor to shield short, or perhaps the cable isn't even connected to the antenna.
videobruce likes this.
CIAO!
Ed N.
egnlsn is offline
post #6 of 17 Old 01-27-2013, 10:07 AM
kenglish's Avatar
Liked: 39
Then, there's also the possibility that someone hooked one screw on the antenna to the center conductor, and the other to the shield.
I've seen that one done before.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #7 of 17 Old 01-27-2013, 10:23 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
+1
I've seen that before too. 300 ohm antenna, coax cable and no balun, why just hook one side of the coax to one screw and the center conductor to the other rolleyes.gif
jjeff is offline
post #8 of 17 Old 01-27-2013, 11:08 AM
gregzoll's Avatar
Liked: 33
I forgot all about those.
gregzoll is offline
post #9 of 17 Old 01-27-2013, 02:47 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
They were worth forgetting about...
CIAO!
Ed N.
egnlsn is offline
post #10 of 17 Old 01-30-2013, 08:54 AM
kenglish's Avatar
Liked: 39
I remember when we tried to put two of those baluns back-to-back, to make a "shield breaker" for the return-patch signal we were sending to TCI Cable (yeah, it was a few years ago).
We could not get rid of the hum....no way!
Took them apart, and found that the local parts house had bought a whole slew of "look-alike" baluns. One wire went to the shield of the coax, the other went to the center pin.
No telling how many were sold across the country.
kenglish is offline
post #11 of 17 Old 02-01-2013, 09:17 AM - Thread Starter
BnLd's Avatar
It took me all week to make time to hunt it down, but Holl_ands got it right. Thanks for your help. At a connection I found a single strand of the shield contacting the center conductor.
BnLd is offline
post #12 of 17 Old 02-01-2013, 11:41 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Those make things so much fun! Glad you found the culprit.
CIAO!
Ed N.
egnlsn is offline
post #13 of 17 Old 02-01-2013, 01:30 PM
holl_ands's Avatar
Quoted: 439 Post(s)
Liked: 182
I think I've made that inspect for stray wire recommendation dozens of time.....
But you're perhaps the FIRST to actually admit they found it....congrats.....
No one else seems to want to talk about it.....
post #14 of 17 Old 02-01-2013, 02:02 PM
gregzoll's Avatar
Liked: 33
That is all it takes. As for the Stinger, I usually only leave about a 1/8", or the thickness at most of Quarter sticking out. That way, the stinger goes in first, then you turn the connector counter-clockwise to get it to sit, so it is not cross-threaded, then tighten clockwise until tight.
gregzoll is offline
post #15 of 17 Old 02-03-2013, 09:24 AM
kenglish's Avatar
Liked: 39
I picked up one of those radio magazines last night, and the author was saying he gets more channels with the transformer removed, and the balanced feed wired to the unbalanced coax.
kenglish is offline
post #16 of 17 Old 02-06-2013, 07:27 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
BTW, those Raychem fittings weren't that bad except for the RG59's with the barrel falling back from the center when disconnected.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #17 of 17 Old 02-06-2013, 03:47 PM
RCbridge's Avatar
Quoted: 16 Post(s)
Good job finding the issue>
RCbridge is offline
Reply HDTV Technical
