OTA "Rural" Arkansa (Morriton), Is it even worth trying? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-31-2013, 10:20 PM - Thread Starter
knightsilver's Avatar
Im not allowed to put up an outdoor antenna.
My apartment is on the northside of a small hill, the broaodcast towers are on the southeast-ish "opposiet" of the hill, thoe towers are 30ish miles away.
The black is the hill I set behind. And my apartment is actually torwards the the end of that cherokee court......The hill is taller than what I can see over, maybe a good 20feet tall or so, but thats guessing....
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1ddab742178da6
and
http://www.antennaweb.org/Stations.aspx?Address=Cherokee+Court&City=Welborn&State=AR&ZIP=72110&Housing=S&Accuracy=5&Height=6&Obstructed=False&StationList=&Lat=35.150398&Lon=-92.7574565
Looking at a Terk HDTVA:
http://www.crutchfield.com/p_209HDTVA/Terk-HDTVa.html?showAll=N&search=hdtva&skipvs=T#details-tab
Yall need anymore info?
Im also OK with just getting KTHV 11.1 and KATV 7.1 channels.
KS
knightsilver is offline
post #2 of 2 Old 02-01-2013, 06:09 AM
mikepier's Avatar
Quoted: 16 Post(s)
You are going to have issues unless you somehow put the antenna outside, or at least high enough in your apt to get over that hill.
Do you live on a second or third floor? Can you somehow mount an antenna on the wall outside your window, or balcony if you have one? The ANT 751 is a small antenna.
Also just for curiousity, re-post your tvfool results, but this time when you enter your data, put in 20ft for antenna height just to see if reception improves.
mikepier is offline
Reply HDTV Technical
