questions about coax - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-06-2013, 10:48 AM - Thread Starter
notbarkingdog's Avatar
I had the AT&T guy out two weeks ago, and he told me that "errors" can accumulate in the coax, which I found hard to believe. He wanted to install something that would cost me $150.00. I told him no, but now my cable isn't working again. Is he correct? Can errors pile up in what is basically a copper wire?
notbarkingdog is offline
post #2 of 5 Old 02-06-2013, 10:54 AM
Thread Ender
WS65711's Avatar
Quoted: 510 Post(s)
Liked: 341
Either you misunderstood what he said or meant, or the AT&T guy was a real idiot. rolleyes.gif
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 5 Old 02-06-2013, 11:28 AM
jjeff's Avatar
Quoted: 778 Post(s)
Liked: 278
It might make sense if he said that the coax was causing errors on the line(bad/cut coax or bad end) and replacing the cable would fix the errors. I had a Comcast guy out just yesterday who said a line was causing errors on the whole main line, which his little graph machine clearly showed. Turns out all it was was a bad cable end hooked to a DTA, he replaced the end and the errors went away smile.gif I thought it was odd that something as simple as a bad end could cause errors all the way back to a main line(very thick stiff line that feeds many distribution amps) but I saw it with my own eyes. No way anything "accumulates" in the wire though.
jjeff is offline
post #4 of 5 Old 02-06-2013, 11:46 AM
SAM64's Avatar
Liked: 78
It's a transmission line. A bad termination on a high power transmitter output could cause it to go up in flames.
SAM64 is offline
post #5 of 5 Old 02-06-2013, 02:45 PM
RCbridge's Avatar
Quoted: 16 Post(s)
His explanation to you was very poor, however as stated a bad cable or cable connector can give you issues.
What was he trying to sell you for $150.00?
RCbridge is offline
Reply HDTV Technical
