New Time Warner Cable Box (Motorola) pass through Onkyo TX NR-609 NO VIDEO!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-08-2013, 11:20 AM - Thread Starter
Pttitans's Avatar
I was having an issue with the older cable box so I picked up the new motorola box. I simply reconnected the HDMI as before and I am only getting audio, no image appears on the screen. If I bypass receiver I have no issue but then what's the point of the beautiful 5.1 system?! Does anyone know what I might be missing? The Time Warner Technician was clueless.
Pttitans is offline
post #2 of 2 Old 02-08-2013, 12:08 PM
mikepier's Avatar
Quoted: 16 Post(s)
Sometimes when you hot-swap HDMI components, the handshake signals get screwed up. Try unplugging all components from the wall for about a minute, then plug back in ( with all HDMI cables in correct ports), then power back up.
If you still have problems, try a different HDMI port on your Onkyo.
mikepier is offline
Reply HDTV Technical
