720p vs 1080i for OTA signals? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-09-2013, 10:12 AM - Thread Starter
fndngemo's Avatar
Recently installed an antenna in my attic to receive OTA network stations. I'm using a Samsung DTBH260F receiver since my TV doesn't have a built in tuner. The 260F has a toggle switch where I have to choose whether the box outputs the signal as 1080i or 720p. About half my stations are 720p and half are 1080i. It's not really practical to constantly be switching back and forth, so I'm wondering if it would be better to convert the 720p signal to 108i or vice versa?
fndngemo is offline
post #2 of 10 Old 02-09-2013, 10:35 AM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Is your TV 720p or 1080i. I would just set the tuner to match your TV.
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 10 Old 02-09-2013, 10:38 AM - Thread Starter
fndngemo's Avatar
TV is 1080p, so I assume 1080i would be the best choice?
fndngemo is offline
post #4 of 10 Old 02-09-2013, 10:44 AM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
That's what I would choose. Your tuner should then pass the 1080i stations through to the TV unmolested. The 720p stations will be output by the tuner as 1080i to match your TV.
Blu-rays & DVD's
WS65711 is offline
post #5 of 10 Old 02-09-2013, 11:11 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
That's how I have mine setup.
CIAO!
Ed N.
egnlsn is offline
post #6 of 10 Old 02-09-2013, 12:16 PM
RCbridge's Avatar
Quoted: 16 Post(s)
If you are stil deciding, I would just flip the switch and look at the TV in both positions and decide from what you see whichever looks best to you!!
RCbridge is offline
post #7 of 10 Old 02-09-2013, 01:34 PM
holl_ands's Avatar
Quoted: 434 Post(s)
Liked: 179
720p is 60 Hz Framerate, whereas 1080i is 30 Hz Interlaced....so the ability to follow motion better with the faster update rate of 720p is LOST when converting to 1080i. Best of BOTH worlds is to enable both 720p and 1080i output on Tuner Box and let the HDTV do conversion to 1080p with it's built-in motion adaptive upscaler...which would operate at 120 Hz (or 240 Hz) in LCD/LEDs and up to 600 Hz in Plasmas. BTW: By NOT enabling 480i output, I let my Cable Box upconvert 480i to 1080i (or is it 720p) output to minimize the extra time it takes for the Cable Box to change output resolutions, but you might want to ALSO enable 480i output and let the HDTV upscale using it's presumably more capable motion adaptive algorithms....try looking at scrolling text on an SD program to see if there is any difference.
holl_ands is offline
post #8 of 10 Old 02-09-2013, 02:28 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
I was lead to believe that a 1920x1080 resolution flat panel would always display a 1080p image if fed a 1080i input. Is there a way force that panel to display an interlaced image? confused.gif
Blu-rays & DVD's
WS65711 is offline
post #9 of 10 Old 02-09-2013, 02:51 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
No
qz3fwd is offline
post #10 of 10 Old 02-10-2013, 06:29 AM
Scooper's Avatar
My Samsung DTBH260F doesn't play nice with my Olevia 720 class LED on HDMI / 1080i, but it's fine on Component 1080i. 720p works fine on both.
Another caveat of the Samsung - if you watch an SDTV subchannel, at least on my combo, it stretches the video out, so you have to use the Aspect button on the Samsung remote to get it to display 4:3 content correctly
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Reply HDTV Technical
