Indoor Antenna help in Suwanee, GA (Atlanta area) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-13-2013, 04:57 AM - Thread Starter
jstarling82's Avatar
It's been a while since I've posted here, but I need the community's advice on something. I've recently located to Suwanee, in the Atlanta area, and I want to install an indoor antenna for OTA broadcasts.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1ddaf78343e201
I bought a $35 GE amplified antenna from Wal-Mart, but it doesn't pull in my 2 VHF stations, and the other signals at the lower end of the spectrum are spotty.
What would the group recommend? I'm specifically looking at the Winegard Freevision, but I'm certainly open to suggestions.
jstarling82 is offline
post #2 of 6 Old 02-13-2013, 07:14 PM
deltaguy's Avatar
Quoted: 17 Post(s)
I'd try the Leaf Plus. I have the Freevision and the Leaf, but have never tried the amplified version. It probably won't work for your NBC affiliate. Your best chance for that channel is old school rabbit ears at a length of 29" tip to tip. Good Luck.
deltaguy is offline
post #3 of 6 Old 02-14-2013, 05:57 AM - Thread Starter
The Freevision is supposedly a UHF/VHF antenna. I have one on the way, scheduled for delivery tomorrow, so I'll report back once I get it mounted.
post #4 of 6 Old 02-18-2013, 04:07 PM - Thread Starter
Mounted this in the attic on Saturday, since I couldn't get a whole lot at the ground level. It seems to be working great, even pulling in my VHF stations perfectly. The only problem I'm having is with RF 39 (2-1), which drops in and out enough that it's annoying to watch. I'm going to get up in the attic and try a couple of other positions. If that doesn't work, I might be making a trip to my old house to get the old custom-built 8-bay off the roof. biggrin.gif
post #5 of 6 Old 02-18-2013, 06:09 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
Maybe add a low gain preamp such as Winegard 269 and see if that will prevent the dropouts.
tylerSC is offline
post #6 of 6 Old 02-18-2013, 06:20 PM - Thread Starter
I do have one of those handy.
Actually just got back down from the attic. The wife couldn't watch The Bachelor, which, of course, drove me into the rafters. tongue.gif
Four Feet to the left and eighteen inches closer to the towers, and our signals on most networks went to almost 100%. We lost some of the local transmissions, but I hadn't found anything on those I wanted to watch, anyway. I may tweak it again, as our closest PBS dropped to around 80%, but as long as it's coming in consistently, I'm happy.
I'm also glad I don't have to risk my neck trying to get that other antenna off the old roof in south Ga. biggrin.gif
Reply HDTV Technical
