tired of paying Directv thinking about OTA advice needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-20-2013, 05:25 AM - Thread Starter
alphabanks's Avatar
Guys I'm too the point where I'm sick of paying Directv mostly 90 percent of the shows we watch are on network TV also we use tons of online video Youtube, Netflix, and Hulu. The only thing that I need to do reserach on is if I can access Nick, Disney, and Cartoon network shows online. Anyway guys I have linked a copy of my TVFool report what type of Antenna would you recommend and where should we attach at should we do the attic or outside I've heard that the best reception is achieved from outside mounting. BTW we already run Windows 7 media centers on each tv and we also have an Xbox so I will most likely go with an HD Homerun to bring the signal back in.
Tvfool report
http://imageshack.us/f/94/radarall.png/
pulled from antennaweb.org
Stations Antenna
WABM-DT 68.1 MNT
RF Channel: 36
17 miles at 9°
Yellow
WBIQ-DT 10.1 PBS
RF Channel: 39
17 miles at 9°
Yellow
WBRC-DT 6.1 FOX
RF Channel: 50
17 miles at 11°
Yellow
WIAT-DT 42.1 CBS
RF Channel: 30
17 miles at 9°
Yellow
WTTO-DT 21.1 CW
RF Channel: 28
17 miles at 9°
Yellow
WUOA-DT 23.1 IND
RF Channel: 6
17 miles at 9°
Yellow
WVTM-DT 13.1 NBC
RF Channel: 13
17 miles at 11°
Yellow
W46DK 46 TBN
RF Channel: 46
17 miles at 9°
Blue
alphabanks is offline
post #2 of 14 Old 02-20-2013, 10:43 AM
Super Moderator
DrDon's Avatar
Quoted: 868 Post(s)
Liked: 1726
We need a location in the title and a LINK to the TV fool report, not an image of it.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 14 Old 02-20-2013, 11:00 AM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
You also might get more specific information if you post to the local OTA area for your location.
Otto Pylot is offline
post #4 of 14 Old 02-20-2013, 11:32 AM
gcd0865's Avatar
Alphabanks:
Since one of your stations is on real channel 6, which is in the VHF low band, you'll need a combination antenna capable of VHF-low reception. If you can fit it in your attic, the Winegard 7082 aimed due north should receive everything on your TVFool report down to WCFT-33 just fine (no amplifier should be necessary). The 110" width of this antenna (at the rear end only) is necessary for receiving the VHF low band.
http://www.solidsignal.com/pview.asp?p=hd-7082
gcd0865 is offline
post #5 of 14 Old 02-20-2013, 05:06 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
You need VHF-HI as well, as there is a channel 13 with most of the rest.
The Winegard HD-7082 doesn't have the beamwidth to go 70 degrees. (Channel 33 is at 300 degrees, while the rest are at ~10 degrees)
To get channel 33 (ABC), you'll need to put up a UHF-only antenna and point it at 300 degrees -- maybe even a little bit lower than that. Your broadband antenna will be pointed at 10 degrees. Combine them with a channel 33 JoinTenna (if you can find one. If not, they are far enough apart that a 2-way splitter might work.
CIAO!
Ed N.
egnlsn is offline
post #6 of 14 Old 02-20-2013, 06:30 PM - Thread Starter
alphabanks's Avatar
Ok guys so there is not just one antenna that will be able to pick up every channel I looked for those JoinTenna's and they seem to be discontinued? If you can't do the JoinTenna option what is an alternative and what are the pros and cons?
post #7 of 14 Old 02-20-2013, 07:23 PM
jtbell's Avatar
His stations are rather close and all the major networks except ABC are very strong. I think there's a good chance a single good full-range antenna would pick them all up, if aimed towards ABC, especialy if it's outdoors.
jtbell is offline
post #8 of 14 Old 02-20-2013, 07:33 PM - Thread Starter
alphabanks's Avatar
post #9 of 14 Old 02-21-2013, 12:23 PM
Otto Pylot's Avatar
Liked: 852
My 28 year old Winegard (the closest model is the CA-8100) has 79 active elements (42 UHF, 37 VHF) and is roof-mounted at about 30' from ground. I have a rotor but never have to use it because I get everything in our market at about a 50 mile distance (LOS is excellent though).
post #10 of 14 Old 02-21-2013, 12:56 PM
gcd0865's Avatar
Oops (thanks for correcting me, egnlsn), I missed that your real channels 3, 18 and 33 are off at 300-302 degrees true. Egnlsn is right that the Winegard HD-7082 probably won't have the beamwidth for 70-degree off-axis reception. Since most of your northerly stations are within 20 miles, and channels 3, 18 and 33 are 36-38 miles away (as a slight variation from jtbell's advice), you could cheat a bit with the aiming and test aiming directions around 315-320 degrees (closer to 301 degrees than due north, since those are your farther/weaker stations) and see if you can find a compromise fixed aim that receives all stations well. If that didn't work well, you could add a rotator and simply rotate the antenna as necessary. Or, if you didn't care about channel 3, then you could use a separate UHF-only antenna aimed toward 301 degrees for channels 18 and 33, aim the 7082 around 10 degrees true, and run separate coax lines from the two antennas down to an A/B switch next to your tv.
gcd0865 is offline
post #11 of 14 Old 02-21-2013, 01:02 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
The concern here is that while most of his stations are in one direction, ABC is 70 degrees away.
CIAO!
Ed N.
egnlsn is offline
post #12 of 14 Old 02-21-2013, 03:18 PM - Thread Starter
alphabanks's Avatar
Guys I see your point now about ABC I purchased a cheap 10.00 RCA antenna and hooked up it up I was able to pull every channel expect ABC the quality was also good. However, I would like to ask can using an amplifier improve picture quality? So it looks like I will be leaning towards an attic install. Also guys I forgot to mention I'm wanting to recieve WJSU-TV which is 40.1 we don't care about the ABC network at channel 30.1.
post #13 of 14 Old 02-22-2013, 06:42 AM
dave73's Avatar
The Winegard HD7082 would be a good choice for your location. Even the Antennacraft C290 would be a good choice. After looking at the rabbitears.info site, it looks like WCFT on RF 33 (vc 33.1) & WJSU on RF 9 (vc 40.1) both simulcast ABC, along with being simulcasted on LPTV station WBMA-LD on RF 40. Even WDBB & WTTO simulcast CW. So having an antenna pointed at 353 degrees makes no sense. So only 1 antenna is needed around 9 degrees.
dave73 is offline
post #14 of 14 Old 02-22-2013, 06:57 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Good discovery!
CIAO!
Ed N.
egnlsn is offline
Reply HDTV Technical
