On upgrading a 45+ year-old OTA distribution system in my condo - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 02-25-2013, 10:16 AM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
The TA-52 was a good amp in its day. Your main issue is the distribution system. You can have the absolutely best antenna and distribution amp that money can buy, but if the distribution system sucks, you won't get good service.
CIAO!
Ed N.
egnlsn is offline
post #32 of 45 Old 02-25-2013, 02:11 PM - Thread Starter
gring40's Avatar
I understand that, really do, and know that I need to first map out and fix the distribution system; you seem to be saying that the amp should be good enough once I do that. The mapping will take some time, after which I'd like to pick things up again to ask how to determine the value of the drop taps in the lines I need to update. Thanks very much for your help.
gring40 is offline
post #33 of 45 Old 02-25-2013, 03:37 PM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
Good luck with the mapping project. Don't worry about any numbers that might be on any of the wallplates. Just a map of the cabling with approximate footages is all that is needed at this point. After that, it's just "Do the math."
CIAO!
Ed N.
egnlsn is offline
post #34 of 45 Old 11-09-2013, 02:03 PM - Thread Starter
gring40's Avatar
I'm back with more questions and some answers. To recap, we have an HD antenna, a fairly new TA-52 distribution amp, a bank of 45-year-old splitters, and RG59U cabling running to twin-lead wall-plates in the units. It looks like our building antenna distribution system is in fact wired in vertical tiers, and that our splitters are doing badly with the higher UHF broadcast frequencies (bypassed the splitters to test that).
I'd like to replace them with new ones, and am asking if those found on the Monoprice site would be ok, and if not, what would be recommended?
I'd need to replace a 2-way, a 3-way, and two 4-way splitters, from which the drops to the tiers emanate.(I've made some progress mapping the drops, with more to go.) Thanks
gring40 is offline
post #35 of 45 Old 11-10-2013, 09:06 AM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
I was going to say the Monoprice splitters would be fine, but then I decided to look at the specs. 10.5dB loss through a 2-way splitter? That's about what most manufacturers' 8-way splitters lose. Most 2-way splitters have an insertion loss of ~3.5dB.
CIAO!
Ed N.
egnlsn is offline
post #36 of 45 Old 11-10-2013, 09:44 AM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 919
Call them. That's got to be a typo. It says 10.5dB for any of their splitters.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #37 of 45 Old 11-10-2013, 12:10 PM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
Look also at the 8dB Return Loss listed. That doesn't even come close to what most industry manufacturers build.
CIAO!
Ed N.
egnlsn is offline
post #38 of 45 Old 11-10-2013, 04:12 PM - Thread Starter
gring40's Avatar
OK, so the specs on the Monoprice splitters are either misstated or subpar; I'll check. Meanwhile, which brands would be trusted? I see some Extreme splitters on Amazon which seem to be selling well; are these a known quantity?
gring40 is offline
post #39 of 45 Old 11-10-2013, 06:44 PM
ctdish's Avatar
Quoted: 71 Post(s)
Liked: 35
It's is a little odd that all of the Monoprice splitters have the same specs regardless of the number of ports.
john
ctdish is offline
post #40 of 45 Old 11-10-2013, 06:52 PM
bdfox18doe's Avatar
Quoted: 219 Post(s)
Liked: 121
john
Not really..anyone who understands the basic math of a splitter knows that it is a typo by someone in marketing that has no idea what they are selling..tongue.gif Besides, everyone knows Monster brand is better because it costs more..wink.gif
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is online now
post #41 of 45 Old 11-11-2013, 05:37 AM
kenglish's Avatar
Liked: 40
If you have access to a Signal Level Meter, or a Spectrum Analyzer, you could use one of those triple or quad NTSC Modulators from Channel Plus, and send several different frequencies through the system at once, measuring the levels at each drop.
That would help you figure out the layout and losses.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #42 of 45 Old 11-11-2013, 08:53 AM - Thread Starter
gring40's Avatar
Sorry, but I don't have access to that equipment, and have been using a lower-tech but workable method to figure the layout. I connect a TV to the wall-plate, tune to a stronger channel, call my cellphone from another phone left by the TV, listen for the loss of audio as I disconnect the cable drops, and tag the cables appropriately. I get a relative measure of signal strength from the TV's DTV "meter".
To do the job properly, it would make more sense to find a competent vendor; is there a recommendation in the Chicago (or North Suburban) area?
Meanwhile, I find that decent quality splitters are not all that expensive, and like the form factor of these; would they be suitable for our MATV distribution system?
http://picodigital.com/product-details.php?PID=95
gring40 is offline
post #43 of 45 Old 11-11-2013, 10:14 AM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
Originally Posted by gring40 View Post
... we have an HD antenna, a fairly new TA-52 distribution amp,
Actually, you more likely have a newly purchased TA-52 amplifier, as I doubt that anyone has manufactured a new unit of that product in this century. The antenna business is notorious for selling "new, old stock". When I buy RG-11 crimp-on connectors, I'm sure they were made decades ago, and the MX-4 channel combiners that I grab whenever I stumble across any have never borne a manufacturing date any newer than 1992. I still use TA-52s on sit in a few places, but with old amplifiers, the mechanical adjustments, like gain potentiometers and the 10 dB attenuator and FM trap switches, can become touch sensitive, which is a problem you might have difficulty detecting without a responsive signal meter to detect their problems, should they ever arise.
a bank of 45-year-old splitters,...
I service a ten story hotel in Washington, DC where we are sending out signals on midband (120-174 MHz) and then superband and hyperband (216- to about 400 MHz) through five nice RG-11 branch cables, but they each split in the plastered ceiling and actually tilt over 20 dB after they each go through single, 2-way splitters that must have been manufactured 60 years ago when this building was built and they probably are VHF only. For now, I have five huge Blonder Tongue BIDA amplifiers, one on each line, to enable me to "muscle" enough superband signals through them, but when I tried diplexing in local broadcast UHF channels, they were a no-go. I've been in the master antenna system business for a long time, but I have never seen any splitters roll off abruptly above VHF frequencies the way these do. it would really behoove you to buy a cheap used signal meter on eBay for a hundred bucks (Sencore 1453 and 1453i are commonly available in that price neighborhood) because you won't always be able to reliably detect the incorporation of hidden splitters without one
AntAltMike is offline
post #44 of 45 Old 11-11-2013, 11:39 AM - Thread Starter
gring40's Avatar
Sadly, I suspected that, and it burns all the more as the amp the installer replaced was ...... a TA-52 mad.gif
It would really behove you to buy a cheap used signal meter on eBay for a hundred bucks (Sencore 1453 and 1453i are commonly available in that price neighborhood) because you won't always be able to reliably detect the incorporation of hidden splitters without one
Thanks, I'll keep an eye out for a meter, but the only one up now is going for $225. I'm hearing the observation that replacing the old splitters I can see may well miss the ones I can't.
gring40 is offline
post #45 of 45 Old 11-11-2013, 12:00 PM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
There's a Sencore 1454, which is a newer and better meter, listing on eBay for $142.50 or best offer that would be nice, but you'd have to make sure you can download a manual before you buy it, because it can be more confusing to operate.
http://www.ebay.com/itm/SENCORE-SA-1454-SIGNAL-LEVEL-METER-/310762205606?pt=LH_DefaultDomain_0&hash=item485adef1a6
If you do buy a Sencore meter, PM me and I'll find you a source for battery packs for about $20 each. Sencore sells them for about $60 to $70.
Whatever you do, DON'T buy the Sencore SL753D. They can't be made to evaluate digital signals without mapping the desired channels into a channel plan individually, and incredibly, the original factory instructions for that meter do not tell the owner/operator how to do that. Several years ago, Sencore could only send me a magazine article telling how to create such a channel plan for the similar, subsequent model SL754D, but it was not the same and took me between five and ten minutes of hacking per channel built before I gave up and threw it away.
You can use any broadband amplifier that begins with the part number ACA as long as it isn't a -450 or -550 model. Lots of manufacturers call their amplifiers ACA or CA. and most now go to 1000 MHz. You should have no trouble finding one for $130 or less, new.
Reply HDTV Technical
