Loss is signal with hdmi wires and splitters. - AVS Forum
post #1 of 10 Old 02-24-2013, 07:04 AM - Thread Starter
jonnypro's Avatar
This is what i set up. I have Apple TV upstairs that goes to a 1in 5 out Hdmi powered splitter. I have this running to my living room TV with a 6' cable. Running to my sons room 12' cable. It then goes downstairs with a 6' cable to a non powered splitter that goes to the master bedroom 50' cable and the downstairs TV. Now I also have my Xbox downstairs that runs a 50' to a non powered splitter to my upstairs TV 12' then to the master bedroom 50'. Now the problem that has been going on is that the Apple TV works on the up stairs TV and my sons room but in the master bedroom it goes to connect and the signal goes in and out. I think I might need powered splitters to amplify the signal because I didn't have this problem before the splitters. A little advise would be grateful. Ty.
jonnypro is offline
post #2 of 10 Old 02-24-2013, 03:26 PM - Thread Starter
jonnypro's Avatar
Not everybody at onece!!
jonnypro is offline
post #3 of 10 Old 02-24-2013, 05:12 PM
Colm's Avatar
Liked: 87
There is no such thing as a non-powered HDMI splitter. There are splitters that take their power off the 5V line of the HDMI cable and splitters that have their own power supply. The former have a very poor track record. The 5V line was never intended to power devices like splitters. Using appropriate splitters would certainly be one step in solving your problem.
Colm is offline
post #4 of 10 Old 02-24-2013, 08:08 PM
sitlet's Avatar
a 50 foot run after two splitters is just too much. HDMI isn't meant to be split in the first place. You can try an hdmi over cat 5 extender, but again, with all of your splitters involved, it may not work.
sitlet is offline
post #5 of 10 Old 02-24-2013, 10:28 PM
Colm's Avatar
Liked: 87
Nonsense, but this sure is an extreme example...
Colm is offline
post #6 of 10 Old 02-25-2013, 01:54 PM - Thread Starter
jonnypro's Avatar
Would you recommend a powered splitter. Would that help the signal.
jonnypro is offline
post #7 of 10 Old 02-25-2013, 02:39 PM
Ratman's Avatar
Quoted: 83 Post(s)
Liked: 243
50' for an HDMI cable is really and literally pushing it. Introduce a splitter and that adds to the signal loss.
Consider this:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=8158&seq=1&format=2
Ratman is online now
post #8 of 10 Old 02-27-2013, 05:01 AM - Thread Starter
jonnypro's Avatar
Because if I only have one TV on at a time it seems to be fine, I did have to unplug the hdmi cable from the set and plug bavk in and it was fine. But when multiple TVs are on it will not work on the furthest screen from the source. It will either flicker on and off every second or not be on.
jonnypro is offline
post #9 of 10 Old 02-27-2013, 09:30 AM
sitlet's Avatar
That's exactly why hdmi is not meant to be split. A source device is meant to connect to one display device. When a source sees multiple devices, it generally will only work with the first one connected.
sitlet is offline
post #10 of 10 Old 02-27-2013, 10:53 AM
DDK65JAG's Avatar
If all of these "splitters" are just that, they are not amplifying the signal at all,
powered or not.They just add to the signal degredation.If thse splitters are like the
approx $40 variety at Monprice they don't amplify, perhaps a booster (which they
do sell) placed before the first splitter may help.
At least that's my take on it, DDK
DDK65JAG is offline
Reply HDTV Technical
User Tag List
