Missing one VHF channel (Toledo, OH) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-28-2013, 06:25 AM - Thread Starter
fndngemo's Avatar
I recently installed a ClearStream 2V antenna in my attic. Almost all of my UHF channels have maximum signal strength according to my tuner box, and one of my two VHF channels (13) has about 3/4 strength. I have one channel (11) that I barely get any signal from, most times it won't even show up. All of my channels are within 10 degrees of each other and are all about the same distance away. Anyone have any suggestions on how to get that last channel to come in? Do I need a bigger antenna?
*edit* Here's a link to my TV Fool report. http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1ddac8ac0366c3
fndngemo is offline
post #2 of 4 Old 02-28-2013, 10:15 AM
mikepier's Avatar
Quoted: 16 Post(s)
VHF is always going to be harder to get with an indoor antenna. It sounds like you have the correct antenna. Are the dipoles fully extended on the antenna and pointing sideways? You are close enough to the towers that you should be able to get those stations. Make sure you aim the antenna towards the ENE where your towers are, and the higher you go, the better.
mikepier is offline
post #3 of 4 Old 03-01-2013, 11:11 AM
gcd0865's Avatar
One possible and inexpensive solution would be to add a Y5-7-13 VHF-high antenna and join it with your ClearStream 2V antenna using a UVSJ. The Y5-7-13 would provide more gain on VHF-high than the simple dipole on the ClearStream 2V. VHF signals do tend to be reduced a bit more than UHF signals in an attic setting.
http://www.solidsignal.com/pview.asp?p=y5-7-13
http://www.solidsignal.com/pview.asp?p=uvsj
gcd0865 is offline
post #4 of 4 Old 03-01-2013, 04:26 PM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
A C2V already has a UVSJ as part of the antenna.
Original versions have it attached to the bottom of the reflector. New versions have it built into the loop assembly which has a VHF IN connector on the back of loop in addition to the output F-connector.
ProjectSHO89 is offline
Reply HDTV Technical
