HDTV Inline Amplifer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-28-2013, 07:47 PM - Thread Starter
MarioMania's Avatar
I have a HDTV inline Amp 30dB 40-2400 MHz, Ultra High Gain
I hook it up to my DTV Converter Box, the Other end to the Antanna Part...Nothing
Output RCVR: Antanna in going to the DTV Box
Input LNB: UHF/VHF Antanna
6ft Cable I'm using
My reception is bad here, I'm in the Valley in Vallejo
MarioMania is offline
post #2 of 12 Old 03-01-2013, 06:07 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Boosting a bad signal just gives you an amplified bad signal.
You should try to reorient your antenna and/or get a "better" antenna.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 12 Old 03-01-2013, 07:29 AM
mikepier's Avatar
Quoted: 17 Post(s)
Post your tvfool results so we can get an idea of reception in your area.
mikepier is offline
post #4 of 12 Old 03-01-2013, 07:49 AM
Ratman's Avatar
Liked: 1191
And... make/model of the amp you're using, make model of the antenna you're using, where the antenna is mounted/located, length of each (individual) coax runs, problematic symptoms prior to the introduction of the amp and which channels were good and bad prior to the introduction of the amp.
Ratman is offline
post #5 of 12 Old 03-02-2013, 06:08 AM
RCbridge's Avatar
Quoted: 16 Post(s)
I hook it up to my DTV Converter Box.
From OTA antenna to an amp to a DTA box to your TV is this correct.
RCbridge is offline
post #6 of 12 Old 03-02-2013, 08:10 AM
DDK65JAG's Avatar
Mario....Like others I'm a bit confused by your post.
I'm going to assume your DTV converter is a DirectTv
satellite receiver,if so you can't connect your tv antenna
to the LNB input, it would have to connected to the antenna(ANT)
input. If the DTV box is not on an active subscription it may not
passthrough the tv signal. Try going antenna directly to the tv set.
Good luck, DDK
DDK65JAG is offline
post #7 of 12 Old 03-02-2013, 10:54 AM
Ratman's Avatar
Liked: 1191
Just so we're on the same page....
DTV is Digital TV (antenna and OTA tuner, whether external or internal to the TV)
D* is DirecTV (satellite dish and receiver)
Which are you referring to?
An inline amp can be different. Is it an antenna premp (at the mast), a powered booster between the antenna and tuner or a bullet type amp that is powered by a satellite receiver?
I'm not a dentist. You shouldn't have to pull teeth to get information to solve a problem.
Ratman is offline
post #8 of 12 Old 03-02-2013, 12:08 PM
AntAltMike's Avatar
Quoted: 141 Post(s)
Liked: 63
MarioMania hasn't been online in a day and a half and so he hasn't seen any of these responses, unless he has been lurking.
AntAltMike is offline
post #9 of 12 Old 03-02-2013, 01:24 PM
Ratman's Avatar
Liked: 1191
Based on this and past posts/threads by the OP, this is just par for the course. rolleyes.gif
Ratman is offline
post #10 of 12 Old 03-03-2013, 05:47 AM
RCbridge's Avatar
Quoted: 16 Post(s)
To the OP if you are still reading these responses, we are not trying to be negative, our goal is to be helpful and educate.
So if you are we await some more facts from you, you can begin with the make and model of all components from the antenna to the TV (or just give us what you have).
RCbridge is offline
post #11 of 12 Old 03-04-2013, 12:15 AM - Thread Starter
MarioMania's Avatar
I got my answer, thanks for the help guys
post #12 of 12 Old 03-04-2013, 04:02 AM
Ratman's Avatar
Liked: 1191
And.... what was the answer????
Ratman is offline
Reply HDTV Technical
